Dry Rotted Carpet Pad Stuck To Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 07-24-2018, 08:51 PM   #1
Rewards Points: 64
Dry rotted carpet pad stuck to hardwood
I recently removed some 50 year old shag carpeting from the house and the green carpet padding is totally dry rotted to the wood. It isn't gummy it is like a hard packed powder or cement with some loose areas turning to dust/smaller pieces.
I've been at it with a medium sized scrapper but in most places it is amazingly hard. It can take a half an hour of chisseling over and over to do just a few ft2. I have nearly 1000ft2 of it.
-I tried ammonia/water nothing.
-drill brush too hard no effect
-drill wire wheel still little effect.
-heat gun on maximum hoovering on one area it gets a little gooey/flexible and can be scraped off but even slower than manual scraper.
-tried renting floor buffer and coarsest buffing pad. Buffer just spun out of control the second it got power.
-Citristrip turns it into goo but it is too expensive for 1000ft2 and makes a huge mess.
Any suggestions? Angle grinder with diamond cup or Diamabrush?
sschoe2 is offline   Reply With Quote
Old 07-25-2018, 08:48 PM   #2
Rewards Points: 996
Re: Dry rotted carpet pad stuck to hardwood
belt sander. the larger the better.
Fix'n it is offline   Reply With Quote
Old 07-27-2018, 08:28 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,650
Probably what they called "bubblerubber". It actually was made from a clay base and turned back to a hard clay when it got old. Almost impossible to remove without sanding.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-02-2018, 01:26 PM   #4
Rewards Points: 64
Yep so far I haven't found any efficient way to remove it. I tried ammonia, vinnegar, mineral spirits, boiling water. It just sits on top of it. The only success I've had is with a long handled scraper which takes 30-60 minutes of just wacking and chisseling at it to get 1 Ft2 leaving some residue behind or heat gun, oven mit hand scraper. With the heat gun it has to be on maximum and held there for several minutes over one small spot to get it hot enough to soften and get with the scraper (it also set off the smoke alarm). It also took about 30 minutes for 1 ft2.
Wood Diamabrush on either an angle grinder or floor buffer?
Old 08-02-2018, 01:40 PM   #5
retired framer
Rewards Points: 20,338
Try soaking it with cooking oil, can't remember what we used but it worked on the crap from the old indoor outdoor carpet.
Old 08-04-2018, 03:42 PM   #6
Rewards Points: 64
No help either. Long scraper or heat gun on some really bad areas seem to be only thing that is working. Even then some areas are just melted on and will have to be sanded and refinished looks like. I may try a little citristrip on the residual areas.
Old 08-04-2018, 03:46 PM   #7
retired framer
We were working on a concrete floor and some oil was spilled by accident and not cleaned up right away. To bad, must be different type of rubber.
Old 08-04-2018, 03:56 PM   #8
Property Mgt/Maint
Rewards Points: 6,524
Hard to believe you would need something this aggressive for a carpet pad, but maybe!
This is a floor scraping attachment used with a SDS demolition hammer
Yodaman is offline   Reply With Quote
Old 08-04-2018, 04:27 PM   #9
kwikfishron's Avatar
Rewards Points: 328
The pad has probably bonded to the polyurethane finish not the wood.
Try a 50/50 mix of lacquer thinner and denatured alcohol. That will dissolve the poly (if that's what's there) and the pad residue should come up with it.
Nealtw likes this.
kwikfishron is online now   Reply With Quote
Old 08-04-2018, 06:22 PM   #10
Rewards Points: 368
Many tool rental shops including the Home Depot rent buffer heads that work great for this. One of the main ones is called a Dimabrush. They also have a couple of others that do the same thing.
Awoodfloorguy is offline   Reply With Quote
Old 08-04-2018, 07:15 PM   #11
Rewards Points: 1,756
You can buy wide scraper blades that fit into a reciprocating saw; the working edge of the blade is at right angles to where a usual reciprocating saw blade would be. It has a kind of Grade-B horror movie look. Lowes.
ChuckF. is offline   Reply With Quote
Old 08-06-2018, 07:52 AM   #12
Rewards Points: 64
Yea I was thinking diamabrush. I may try some ethanol (denatured alcohol is just ethanol with some methanol[typically about 1%] and isopropanol added so you can't drink it). I typically have some waste from my lab (I am a chemist) but so far every chemical I've tried had had no effect on it short of citristip with started to turn it to green goo. I think I am going to have to use a physical method for the majority of it then use a chemical for the residual spots left over or it is going to have to be sanded but I tried a handheld belt sander and the belt quickly became coated and stuck with it.
Old 08-06-2018, 03:34 PM   #13
Rewards Points: 64
Not sure it would have the force necessary. You really have to ram it with the scraper pretty hard to break it lose from the floor. You also have to hold it tight against the floor or it will skip over it. I have a wider scraper I tried and it flexes too much.
Old 08-06-2018, 03:40 PM   #14
retired framer
[quote=sschoe2;5600023]Not sure it would have the force necessary.
Have you tried heat.
Old 08-06-2018, 04:05 PM   #15
Rewards Points: 64
Oh yea some areas I have to use the heat gun. However, you have to put it on maximum and hold it very close with one hand while using a hand held scraper and oven mit on another hand. It has to get very very hot to get pliable so hot that it sets the smoke detector off. It is very slow going and leaves some stuff behind at the bottom.
Nealtw likes this.
Carpet or hardwood cgrein Flooring 24 10-25-2016 12:28 AM
Carpet advice: Big box stores, budget, pad quality, etc 211 Flooring 1 12-17-2015 03:06 PM
Hardwood to Carpet Transition Piece segal Flooring 5 12-05-2012 06:49 PM
From Carpet to Engineered Hardwood in a Weekend MisterPG Project Showcase 14 02-23-2011 01:48 PM
Carpet on hardwood floor, threshold hoozgrunt Flooring 1 07-15-2009 09:53 AM
