Drop Lock Laminate Flooring Clicks - Flooring - DIY Chatroom Home Improvement Forum
Old 07-24-2014, 10:53 AM   #1
listo's Avatar
Rewards Points: 107
drop lock laminate flooring clicks
I installed drop lock laminate a couple months ago, now when I walk on it I can feel the pieces shift and it clicks with almost every step, I don't really care too much as I'm moving to a new place tomorrow, but just wondering did I install them too tight or too lose? Or is it just a symptom of the drop lock? I've installed the angle angle a few times before and never had this clicking issue.
listo is offline   Reply With Quote
Old 07-24-2014, 11:27 AM   #2
Rewards Points: 144
The floor you installed them on was probably not flat.Or you bought some low quality flooring.
mako1 is offline   Reply With Quote
The Following User Says Thank You to mako1 For This Useful Post:
listo (07-24-2014)
Old 07-24-2014, 11:29 AM   #3
Rewards Points: 18,468
What did you use for an underlayment?
What was it laid over.
Did you make the mistake of just trying to lower it into place in one motion without working it up and down as it went into place to get it fully locked?
I also follow up by tapping along the piece with a white dead blow hammer to make sure it settled into place.
As your tapping you can see any tiny gaps disappear.
listo (07-24-2014)
Old 07-24-2014, 11:44 AM   #4
listo's Avatar
Rewards Points: 107
I used the cheapest underlay I could find,it's laid on a plywood floor that isn't completely level. But not too bad, it's a 14mm laminate but it was cheap, 1$ square ft it was a special order at home depot.
Old 07-24-2014, 12:00 PM   #5
Well theses your answers, perfect storm for later issues.
listo (07-24-2014)
Old 07-24-2014, 12:06 PM   #6
Old 07-24-2014, 01:39 PM   #7
Rewards Points: 144
Yea,you just answered your own question.The floor does not have to be level.Just flat.
laminate flooring over laminate flooring bowbender6 Flooring 6 07-04-2012 09:27 PM
Laminate Wood flooring for duplex jukeboxpunk Flooring 16 06-23-2012 04:39 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 07:34 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
