Is This A Doable Transition? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 08:49 AM   #16
Rewards Points: 145
Originally Posted by jeffnc View Post
Maybe that's because it is? Why didn't you just lay them together the way they'd actually be laid on the floor? That's was about as confusing as could be....
I did!
They are all fitted together as if they were on the floor. But I can see how the flash shadow makes the crossing piece look like it's laying over everything. Having them laying on the boxes instead of a flat surface may also be creating the mistaken illusion.
Brad Nailer is offline   Reply With Quote
Old 04-18-2013, 09:03 AM   #17
Rewards Points: 6,486
Oh I see now. An optical illusion I guess, my bad.
jeffnc is offline   Reply With Quote
Old 04-18-2013, 09:14 AM   #18
Rewards Points: 145
So now what do you think?
Is this something that's been done before? I know changing direction is nothing new, but to do it for one board and then go back again, it doesn't seem like it should be any problem, outside of measuring correctly.
Old 04-18-2013, 09:58 AM   #19
For all practical purposes it's the same thing Jim showed in his second and third photos. As long as the boards have room to expand at the opposite end you should be fine.
The Following User Says Thank You to jeffnc For This Useful Post:
Jim McClain (04-18-2013)
Transition from Vinyl to Wood Question petros151 Flooring 3 02-16-2012 12:42 PM
door jamb cut over transition rtoni Building & Construction 4 10-28-2011 04:50 PM
Tiling entryway - proper transition for this scenario? Scott99999 Flooring 5 12-22-2009 01:12 AM
Engineered Hardwood: Inlaid transition? SteveSmith98 Flooring 6 03-24-2009 12:21 PM
1.75" room / floor transition MrLinux Flooring 1 03-11-2008 03:19 PM
