Do I Need Cork Underlayment? Removing Old? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-25-2014, 09:27 AM   #1
Rewards Points: 41
Do I need cork underlayment? Removing old?
Am about to retile a small bathroom. The floor is concrete, and there is currently a layer of cork beneath the existing tile. I thought cork in a high moisture area was a bad idea? Is the sole purpose of cork underlayment for noise deadening? Can I just lay the new tile directly on the concrete floor? Is a latex fill necessary? Finally, what is the best way to remove the existing cork? Thanks in advance!
slappydan is offline   Reply With Quote
Old 06-25-2014, 09:32 AM   #2
Rewards Points: 41
Additional info:
Plan to put in 12x24 tile
1/8" grout lines
Old 06-25-2014, 09:34 AM   #3
Retired Moderator
Rewards Points: 7,174
Cork is usually for sound deadening---are you in a condo?
What is the subfloor? Concrete or wood?
Old 06-25-2014, 09:54 AM   #4
Rewards Points: 41
Originally Posted by oh'mike
Cork is usually for sound deadening---are you in a condo? What is the subfloor? Concrete or wood?
No, I'm in a single story house. The subfloor is concrete.
Old 06-25-2014, 10:52 PM   #5
Rewards Points: 41
Bueller?
Old 06-26-2014, 05:46 AM   #6
Retired Moderator
The installer may have used the cork as a decoupling membrane---
If you find cracks or other flaws, consider using Schluters Ditra under your new tile--
Old 06-26-2014, 05:46 AM   #7
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Cork is fine in your application. Cork does not absorb moisture. However, it isn't really needed. I'd probably opt for a layer of Ditra instead.
Darkling Designs
poppameth is offline   Reply With Quote
Old 06-26-2014, 08:46 AM   #8
Rewards Points: 41
Thanks for the feedback. Is an underlayment necessary in this application? What is the benefit of laying ditra between concrete and tile - moisture mitigation? If I the concrete is clean and level, is a ditra underlayment still a good idea?
Old 06-26-2014, 08:54 AM   #9
Rewards Points: 41
Perhaps it should be noted that the slab is not new. It was poured in 1990.
Old 06-26-2014, 08:59 AM   #10
Retired Moderator
Ditra is used as an isolation membrane over concrete that has flaws --
If your concrete has no cracks that appear to be active---then setting directly to the concrete is fine.
Removing wall paper & cork from 1973 Waterfroggy Painting 8 03-08-2014 08:09 PM
Cork in new home build that can't withstand a single drop of water :( turnanewleaf Flooring 15 11-05-2013 05:24 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 02:00 AM
Cork underlayment for nailed 3/4" hardwood floor Lubko Flooring 3 06-11-2010 06:35 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
