Difference Between An Engineered Wood Floor And A Solid Wood Floor?? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-16-2015, 03:20 AM   #1
Rewards Points: 104
Difference between an engineered wood floor and a solid wood floor??
What is the difference between an engineered wood floor and a solid wood floor? and which one is better use for my living room..Is this my right decision to use one of them??
marks.fletchers is offline   Reply With Quote
Old 03-16-2015, 09:44 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
A solid wood floor is just what it says, each plank is one solid piece of wood. An engineered is a thin piece of real wood glued to the top of plywood or MDF. Engineered can be refinished a couple times. Solid, many times. Solid needs to be glued or nailed. Some engineered gets floated. Solid costs a lot more. Solid is either site finished or prefinished. Engineered is prefinished.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
MTN REMODEL LLC (03-17-2015), oh'mike (03-16-2015)
Old 03-17-2015, 05:46 PM   #3
Rewards Points: 5,014
http://www.lumberliquidators.com/ll/...geType=product
ron45 is offline   Reply With Quote
Old 03-17-2015, 07:37 PM   #4
Rewards Points: 400
And LL makes some of the poorest quality products,
The Following User Says Thank You to rusty baker For This Useful Post:
Old 03-17-2015, 07:38 PM   #5
Rewards Points: 1,042
You can refinish engineered flooring just as many times as solid wood flooring, it just depends on how deep your pockets are, just remember "you get what you pay for"and you'll be fine, I personally prefer engineered as it has a harder wear layer, i'll post a link for you read it through , the decision is then your's.
http://www.hoskinghardwood.com/Depar...dId=7&pageId=7
Canarywood1 is offline   Reply With Quote
Old 03-17-2015, 08:41 PM   #6
Rewards Points: 400
Engineered's wear layer is not anywhere as thick as solid wood. No way they can be refinished as many times. When you sand an engineered two or three times you are into the core.
Old 03-17-2015, 09:01 PM   #7
I beg to differ, you can get engineered as thick as 10mm.
This is only 1/16 of an inch difference.
http://kaprizhardwoodfloors.com/floo...opic=wearlayer&
Old 03-17-2015, 09:06 PM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 784
And as Rusty says... each eng product has different specs and diffrent finish ply thicknesses for subsequent refinishing.
I think what you want to consider is your usage...and budget... and tolerance for wear.
Are you retired without children and dogs and will treatr a floor lightly... likely not requiruing multiple refinishing..... or is your home such that you want the unmistakenabel quality feel of solid....
Both products... and laminate plastic... have pro's cons.
Seems to me that both products can produce a beutifull aesthetic/visual appeal... but primary differences lie in usage/cost/rehabilitation considerations.
Good luck
MTN REMODEL LLC is online now   Reply With Quote
Old 03-19-2015, 12:28 PM   #9
Rewards Points: 402
Solid wood is wood cut from a tree and then cut to size into flooring panel dimensions, while engineered wood flooring is composed of several layers of wood pressed and glued together to the desired thickness and then cut to the specified dimensions.
Engineered wood floors were developed for use on the first floor of a home built on a concrete slab or in a basement. But engineered wood flooring can be used anywhere, including in places where you'd expect to find plank floors.
fortunerestore is offline   Reply With Quote
Old 03-19-2015, 08:09 PM   #10
Rewards Points: 1,646
http://www.nbcnews.com/business/cons...-tests-n322346
Don't buy any chinese made flooring.
