Difference Between Advantech 'flooring' And 'sheathing'? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-21-2018, 12:22 PM   #1
Thumb smasher
Rewards Points: 32
Difference between Advantech 'flooring' and 'sheathing'?
I ordered 5/8" T&G Advantech panels for my subfloor (to go on top of the 1/2" ply that's already there) from the local lumber yard, they delivered them just now, I checked quick to make sure it was T&G and the right size, etc., and they left.
It wasn't until after that I just picked up a panel to look closer, and I noticed it says "sheathing" on it. When I hit the Huber web site, they have separate pages for for flooring and sheathing.
Can I use this for my subfloor?
I keep reading that you don't use sheathing ply, but I wasn't sure when it came to advantech; and so many sites/comment boards/blogs talk about using Advantech sheathing for their subfloors - but I dunno if that's actually what they are using or if they are just being sloppy with their terminology, or if maybe everything is just marked 'sheathing' and there's some other marking on there that's supposed to indicate it's ok for subfloor/underlayment.
Thanks!
NatRussel is offline   Reply With Quote
Old 05-21-2018, 01:15 PM   #2
Thumb smasher
Rewards Points: 32
Re: Difference between Advantech 'flooring' and 'sheathing'?
Follow up (is there a way to edit a post?):
* The sheathing is marked 40/20, and the data sheet on the flooring says PS2 span rating is 20" oc - so I don't see any differences there.
* Sheathing is a pound heavier on the data sheets, so density should be pretty even - I mean, this is only 1/32" thicker
Is it possible the difference is mainly dimensional because sheathing/flooring has different applications? This is only 47.5" wide, plus 1/8" with the tongue - but I've seem some people talk about getting full 48" materials.
Old 05-21-2018, 01:21 PM   #3
retired framer
Rewards Points: 5,866
I have never seen the stuff you have but the regular stuff when put together never closes up tight and going over a another floor it may be a plus.
Old 05-21-2018, 05:41 PM   #4
Thumb smasher
Rewards Points: 32
I ended up calling Huberwood - whoever would have though you could just ask the people who make it!
The rep said there is no difference between the two from a performance standpoint. The only difference is that flooring is sanded smoother on one face, which is why (I presume) it comes as 19/32 instead of the full 5/8.
I was planning on covering with tar paper anyway under the hardwood, so I doubt the smoothness will matter much.. seems pretty smooth enough to me already.
Tags
advantech , subfloor
Tile and bamboo flooring Big Cat Remodeling 4 02-15-2015 05:58 PM
Residential concrete over sheathing 2nd floor peaks and valleys!! HELP!! dzl13 Building & Construction 20 01-04-2014 10:51 AM
Cheap, lightweight wall ceiling sheathing for attic Phildaglass Building & Construction 3 07-29-2012 08:37 PM
coordinating new door threshhold with flooring muncher Carpentry 2 05-28-2011 11:44 PM
Sheathing or no sheathing? mavityre Building & Construction 2 08-30-2010 05:05 PM
