Cursed, Accursed Laminate Floating Flooring.... - Flooring - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By ront02769
  • 1 Post By MTN REMODEL LLC
Old 01-17-2017, 09:26 PM   #1
Rewards Points: 96
Cursed, accursed laminate floating flooring....
Like a fool, I put laminate 'floating floors' all over the place in both levels of my home, and have been paying the price eternally ever since.
Oh they look nice, but eventually... inevitably, and always, you end up with "puckers".
This is because the designers of traditional laminate flooring made it so that when common spills are left on- say, the house dog having an accident when you aren't home, a leaky roof, a backed up sink, whatever- the liquid is absorbed into the seams, causing them to expand. They do NOT go back down. Leaving a permanent unsightly buckle here, there, and everywhere.
What is more, as laminate is tongue-in-groove, many times you have no option to replace buckled sections without ripping out huge areas, working to the end. That is, assuming they still sell your matching brand and flavor of laminate. Many times, they do not.
So you basically spend your days watching the floor you spent all that time and work on deteriorate worse and worse, while your eye twitches with a nervous tick and looks at the ceiling lol.
So my question is: has any manufacturer had the brilliant idea and let's face it mercy to come up with an affordable *waterproof* laminate flooring, that works?
If so, can you recommend a brand?
I'm willing to rip out and put in a new floor for the third time, but frankly I'd like to be just a little smarter this time.
jeffpas is offline   Reply With Quote
Old 01-18-2017, 12:19 PM   #2
Re: Cursed, accursed laminate floating flooring....
NuCore is a product I just discovered today - it's exclusive to Floor and Decor. Home Depot has a similar product called Resilent Interlocking Planks by Traffic Master. Both claim to be 100% waterproof. They are both between 2.50 and 3.00 a sq. ft.
drewjt6 is offline   Reply With Quote
Old 01-18-2017, 08:20 PM   #3
Rewards Points: 1,368
Not dealing with the waterproof product.....but it is a not necessary to remove entire sections to get to the end. Cut the bad board down the middle, drill holes in the corners, then cut it into triangles and pull it out. You then just cut off the bottom of the groove side of the new board, pop it into place, and glue that side down. As to finding the replacement board, grab it out of the stack of boards that you set aside when you installed it.
MTN REMODEL LLC and jaysurfs like this.
ront02769 is offline   Reply With Quote
The Following User Says Thank You to ront02769 For This Useful Post:
jaysurfs (03-28-2017)
Old 01-18-2017, 10:23 PM   #4
RRH
Rewards Points: 1,336
coretec floors
RRH is offline   Reply With Quote
Old 01-19-2017, 05:01 AM   #5
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,342
If you want waterproof, porcelain wood grain tiles.
I have some in my kitchen and everyone who sees them believes they are real wood at first.
If you want wood, start saving for real hardwood flooring. Laminate flooring should be illegal. How someone can sell that stuff and still sleep at night, I have no idea. Pure junk.
Vinyl tiles are junk as well. They'll get scratched and dinged. I had a brand that the micro coating came up and the core of the tile was white, not brown and you could see every blemish sticking out like a sore thumb.
I'm curious if anyone recommending vinyl actually tiles has had them installed for more than a few years?
Can anyone tell I'm bitter over all the crap that's for sale ion the market today?
People walk into a store and see a nice price for what appears to be a nice looking product only to fall victim to the shysters selling it? After all the hard work and these problems pop up.
OK.....slow down pugsy...rant coming to an end....over.......sorry all.....it just drives me crazy......
Pugsy...my project: http://www.diychatroom.com/f49/total...storey-276978/
123pugsy is online now   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
rusty baker (03-18-2017)
Old 01-19-2017, 08:17 PM   #6
Rewards Points: 1,760
'Accursed' should be the brand name.
ChuckF. is offline   Reply With Quote
Old 03-16-2017, 07:43 AM   #7
Property Mgt/Maint
Rewards Points: 6,566
Glue your seams 100%. It will prevent spills from penetrating the seams. Also prevents seam separation on large areas.
Yodaman is offline   Reply With Quote
Old 03-16-2017, 10:39 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,274
YODA ^^^^^^^^^^^^^100%^^^^^^^^^^^^^^^^^^^
Assuming you want a laminate, a product with glued TnG performs much better in the long run verse a quick lock product.
I had a 1995 Pergo TnG floating glue up (glued TnG... not glue down) that saw 2 dogs/ 2 active kids/ many kegs of beer/ and tracked in snow for 20 years that looked virtually brand new after twenty years of punishment.
Yes, laminate does not have the feel or depth of look that a nice hardwood or engineered wood has, but it does have super low (none) maintenance and durability.
Yodaman likes this.
MTN REMODEL LLC is online now   Reply With Quote
Old 03-16-2017, 12:43 PM   #9
Property Mgt/Maint
I had similar results with a click-lock product that I put down in the mid 90's. It was a kitchen/dinning room with all seems glued up, not down, it was still a floating floor. I sold the house a year ago and the floors still looked good. It had a couple dings from sharp objects falling, but no swelled "puckers".
Old 03-18-2017, 08:17 AM   #10
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,668
I won't install laminate. Too many problems. It is a disposable, temporary, floor covering.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
123pugsy (03-18-2017)
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Laminate Flooring Installation - Guesstimate This Job For Me Please flowerchick Flooring 8 11-19-2011 12:57 PM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
laminate flooring on top of tile newhomeowner808 Flooring 3 09-19-2009 07:34 PM
Basement Flooring: Laminate material atm Flooring 1 06-30-2009 10:34 AM
