Cracking In Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By SeniorSitizen
  • 1 Post By ChuckF.
Old 06-28-2018, 11:44 AM   #1
Rewards Points: 54
Cracking in Hardwood
Hey guys, my wood floors are starting to crack around the edges. What would you suggest to seal these back up? I have some rejuvenate, which i will be applying here in the next couple days. Just wanted to get some opinions and suggestions. What do you guys think?
Cracking in Hardwood-img_2920.jpg   Cracking in Hardwood-img_2919.jpg   Cracking in Hardwood-img_2918.jpg   Cracking in Hardwood-img_2917.jpg
jdr7785 is offline   Reply With Quote
Old 06-28-2018, 12:15 PM   #2
Property Mgt/Maint
Rewards Points: 6,564
Re: Cracking in Hardwood
What is the humidity in the house? Hardwood mfg's recommend 30 to 50 RH all year around. I would guess you are running low on the humidity.
Yodaman is offline   Reply With Quote
Old 06-28-2018, 12:28 PM   #3
Rewards Points: 54
My nest is showing humidity at 50%, but im not sure how accurate that is. I live in Oklahoma, so it is pretty humid at this time of year.
Old 06-28-2018, 12:37 PM   #4
Rewards Points: 1,588
The in house humidity could be well within suggested parameters, but if the wood was 30% moisture content when installed and dried to 6-8 % the cracking we see is the result. That puts a home owner between a rock and that hard spot because we just have to live with it without some kind of filler and that would be butt ugly in my opinion.
Old 06-28-2018, 12:56 PM   #5
Rewards Points: 54
So what is the solution? Do you guys deal with this, too? Any product i can use to seal this up or anything?
Old 06-28-2018, 02:29 PM   #6
If rustic was the target you hit it dead center. Just leave it and enjoy.
SPS-1 and Dave Sal like this.
Old 06-28-2018, 07:17 PM   #7
Property Mgt/Maint
If you are sure your RH is good, probably not much else you can do.
That said, was your installer experienced? Some of the end joint staggers are too close.
Old 06-28-2018, 07:32 PM   #8
Rewards Points: 1,760
That was my thought, the wood looks like what they call 'cabin-grade' in these parts.
Yodaman likes this.
ChuckF. is offline   Reply With Quote
Old 06-28-2018, 08:03 PM   #9
Rewards Points: 1,042
Looks like seconds to me, and yes those staggers are way to close.
Canarywood1 is offline   Reply With Quote
Old 06-28-2018, 08:53 PM   #10
Home Repairer
Rewards Points: 468
Boards of differing widths, off by a 32nd of an inch cause gaps like this on installation. Just looks to be poor quality materials and goofs that should have been caught during the installation process.
czizzi is offline   Reply With Quote
Matching solid hardwood h22lude Flooring 8 11-23-2014 09:58 PM
Installing new hardwood ontop of existing hardwood benshouse Flooring 4 01-10-2014 12:45 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 07:37 PM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 05:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
