Cracked Grout In Wet Room Floor Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 10-26-2015, 10:34 AM   #1
Rewards Points: 4
Cracked grout in wet room floor tiles
Hi,
We have a wet room put in by the previous owners in our en-suite bathroom in the loft bedroom. Some of the floor tile grout has started to crack and come away. There is no obvious damage to the ceiling below and the tiles themselves seem to be firm in place.
What is the best approach? I'm presuming the area has been properly tanked (though I can't confirm this) or there would be some outside damage by now. Can I just regrout? Or should I pull up a tile to investigate further?
Thanks for any assistance.
b/
Bisquite is offline   Reply With Quote
Old 10-26-2015, 10:41 AM   #2
Rewards Points: 18,376
99% of the time grout or tile cracks are from improper prep.
Under sized, over spanned joist.
Particle board as a sub floor.
No tile board used or no thin set under it.
Old 10-26-2015, 10:59 AM   #3
Rewards Points: 4
Thanks for the reply. The wet room is about 2.5 years old so it's taken a while to occur. I'm just wondering if regrouting would be a good solution for another few years?
Old 10-26-2015, 12:21 PM   #4
ZZZZZ's Avatar
Rewards Points: 1,208
Before you can re-grout, you need to use a ton of elbow grease and scrap and dig and remove all the cracked grout. Oscillating tools such as the Rockwell Sonicrafter have attachments specially for removing grout. That makes it go faster, but it is still many hours of work.
If it's a small area with small tiles and a lot of grout lines, it may even be less labor to remove the whole enchilada, tiles and all, and start from scratch.
ZZZZZ is offline   Reply With Quote
Choosing a Color Scheme For Your Room Micheal11 Interior Decorating 0 08-10-2012 11:03 PM
Brainstorming ideas to Dress Up the front room of my new house!! the_d_mann1 Interior Decorating 0 05-01-2011 05:47 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
Cracked grout??? cm3putter Tiling, ceramics, marble 9 03-05-2010 08:49 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 08:28 PM
