Crack In Wood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-15-2013, 08:54 PM   #1
Crack in wood flooring
We are refinishing our hardwood flooring on our stairway. The one step has a pretty large crack and its splintered. We found Elmers Damaged wood repair kit at lowes and were wondering if it would work. We'd like to not have to replace the wood because the house was built in 1895 and we don't believe we'd be able to match any newer wood to the other steps.
pjn18 is offline   Reply With Quote
Old 07-15-2013, 09:53 PM   #2
Rewards Points: 17,914
Any fillers you try to use are going to stick out like a sore thumb.
A tread that wide now would be made from laminated strips of wood not one piece like that one to avoid the cupping and splitting.
Old 07-16-2013, 10:52 AM   #3
Rewards Points: 274
Replacement of wood is not appropriate try as it is very old time.
alexjoe is offline   Reply With Quote
Old 07-16-2013, 01:37 PM   #4
Rewards Points: 2,773
It looks like the tread is removable, since it looks like you have nails or screws fastening it to the riser. Remove it, fasten a piece of 2x reinforcing behind/below. If you can't remove, maybe you can just access it from below the stairs?
Maybe a little sanding will help even the crack out; hard to tell from just pics.
huesmann is offline   Reply With Quote
engineered wood flooring nailer joshanah Flooring 3 06-04-2012 11:21 AM
Vinyl flooring over wood slat subfloor Patricia54 Flooring 6 02-11-2012 02:22 PM
Engineered or Solid Wood flooring on stairs VickyC Flooring 1 03-05-2010 06:50 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
