Cottage Sub Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 10:59 PM   #1
Cottage sub floor?
Hello we have a cottage in northern Ontario in Canada. It is not winterized but we want to make it more comfortable. The floors are really cold. Would anyone recommend putting down a 1/2 inch of rigid foam insulation on the existing subfloor then an osb board then the new floor?
Rlly001 is offline   Reply With Quote
Old 02-03-2012, 11:02 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
No. That rigid insulation will smash down and your floor will be all over the place.
Do you have a crawlspace, or a slab, or a basement?
titanoman is offline   Reply With Quote
Old 02-04-2012, 08:04 AM   #3
The cottage is raised about 2 ft off the ground
Old 02-04-2012, 08:26 AM   #4
Rewards Points: 18,382
Just add R-19 insulation under the subflooring in the crawlspace.
You also need to add a 6 mil. plastic vaper barrier on the bare ground to act as a vaper barrier.
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 07:30 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
