Cost To Repair This Carpet Damage - Flooring - DIY Chatroom Home Improvement Forum
Old 01-15-2016, 09:29 AM   #1
Rewards Points: 378
Cost to repair this carpet damage
Hello.
My dogs chewed up some carpet and I'm trying to get an idea on price to repair the carpet.
My landlord will keep some of my deposit as it is clearly damage, but I want to get an idea on cost before we do the walk through.
Alumifab is offline   Reply With Quote
Old 01-15-2016, 09:35 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 228
It depends on whether you have a piece of replacement carpet. If not the carpet needs to be replaced.
It is also possible to remove a section from a closet.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 01-15-2016, 10:13 AM   #3
Rewards Points: 378
That's what I'm thinking, cut a geometric shape from a closet and some seam tape, etc..... and it should work.
He's probably wanting to replace the whole carpet through the house as most landlords will try to do....
Old 01-15-2016, 12:18 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 228
The patch will be obvious since the carpet from the closet will be look less faded and show no normal wear.
I would ask the landlord
He is within is rights for you to cover the deprecated value.
Old 01-15-2016, 12:22 PM   #5
Rewards Points: 378
I've lived here for 4 years. At what time does the carpet fully depreciate?
If there is life still left in the carpet, I'm not opposed to pay a small prorated amount.
Old 01-15-2016, 01:20 PM   #6
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
How long has the carpet been down, the LL can only depreciate it for 7 years? I would probably charge $100 to fix it but I charge less than most. Maybe a little cheaper if it's a wood subfloor ( I could staynail it then, which makes it faster to repair).
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-15-2016, 01:22 PM   #7
Rewards Points: 400
If the carpet was new when you moved in, he could probably get 1/2 replacement value.
Old 01-15-2016, 01:32 PM   #8
Rewards Points: 378
You guys bring up another question.
Is the replacement/depreciation cost of just the room/s where the damage is or is it of the whole house which has carpet?
Old 01-15-2016, 02:54 PM   #9
Rewards Points: 400
If all the carpet matches, he probably can get the whole house. depends on the type of rental, too. In Sec 8 and other public housing, all the carpet must match and you cannot usually do that after a few months. Carpet colors and styles change too often.
Old 01-17-2016, 08:49 PM   #10
Rewards Points: 1,906
Take a look at the backing on that carpet, it may be rotten from moisture or mold. When that happens it gets easy to tear. Or maybe you have a really big dog.
ChuckF. is offline   Reply With Quote
How to repair outside corner damage on interior walls BarbaraJ General DIY Discussions 19 09-14-2015 08:04 PM
Repair siding / skirt from water damage cfreak Roofing/Siding 3 08-08-2015 01:47 PM
Repair linoleum damage? See Pic. Ultrarunner2017 Flooring 2 12-06-2012 07:46 PM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 03:40 PM
How to Repair Spot Damaged Carpet jrguy Flooring 1 08-25-2009 07:45 AM
