Coretec Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 06-13-2017, 03:32 PM   #1
Rewards Points: 2
Coretec flooring
I am trying to install coretec 7inch flooring but even after watching the videos I'm having a really hard time getting it to click in at short ends.
Any tips would be really appreciated
britney358 is offline   Reply With Quote
Old 06-13-2017, 07:17 PM   #2
Rewards Points: 17,912
Re: Coretec flooring
#1, Examine every single piece for damage, cut out flaws with a utility knife.
Here's what works for me, I align the short ends and assemble them first making sure there 100% lined up.
Instead of just trying to set it in place and lowering it to the floor in one pass, I lower than raise it a little getting lower each time until it's flat on the floor.
I assemble a whole row at a time then install it as one long piece using at least two people.
Once again lowering it then, raising working it into the lock.
Once in place and there's 0 gaps I tap over the whole thing with a white rubber mallet, doing that will stop it from trying to lift up off the floor.
If your trying to use the cheap Pergo branded install kit, stop, go buy a Roberts band tapping block and Z bar.
The tapping block is at least twice as big and better built, and the Z bar is thicker, wider, and longer plus has a felt pad to get the metal away from the flooring. I think I got mine at Lowes or HD.
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
removing laminate flooring mikeinMemphis Flooring 24 02-24-2013 09:06 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 12:21 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
