Copper Subfloor Underlayment? - Flooring - DIY Chatroom Home Improvement Forum
Old 12-02-2015, 03:08 PM   #1
Rewards Points: 14
Copper subfloor underlayment?
My NJ house was built in 65 and has a den that I believe is on a concrete foundation, as the basement does not go under it. It is carpeted now and I want to install a floating wood floor in the room. I remove both register covers to verify the subfloor and it looks like there is a sheet of copper under the carpet padding. Has anyone heard of this? I am not sure how to work with this. Thanks in advance
Jonscheets is offline   Reply With Quote
Old 12-02-2015, 03:11 PM   #2
Rewards Points: 18,382
Highly unlikely, and I'd have to see it to believe it.
If the carpets coming out anyway remove the 1/4 round and pull the carpet back for a better look.
CompleteW&D (12-02-2015)
Old 12-02-2015, 05:16 PM   #3
Rewards Points: 744
maybe it's foil tape, often used to air-seal the gaps between the air register and subfloor?
Seattle2k is offline   Reply With Quote
Old 12-02-2015, 05:23 PM   #4
That would be my guess.
Way to expencive to use now.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
copper clad aluminum CopperClad Electrical 45 06-23-2012 04:21 PM
Compression fitting with copper tubing for dishwasher DK75 Plumbing 4 04-27-2012 07:47 PM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Copper hood - Looking for input steve1234 General DIY Discussions 13 01-04-2010 02:34 PM
