Continuing Hardwood Floor Into New Closet - Flooring - DIY Chatroom Home Improvement Forum
Old 09-10-2014, 03:23 PM   #1
Rewards Points: 33
Continuing hardwood floor into new closet
Hello,
I was looking for some guidance on finishing the floor in a small hall closet which resulted from a master bathroom build. I have included a picture. I do not want to refinish my current floor and I though interdigitating the floor would be difficult. I was thinking of making a straight cut perpendicular to the edge and place the new floor perpendicular to the existing as the closet will cover most of it. Or just placing one perpendicular and the rest parallel making a transition. I was also thinking of laying all the pieces out them prefinishing them before installing them. I have a 10 month old son and I am trying to avoid fumes. I have a bunch of the same hardwood saved from ripping out he floor for the master bath.
I am hoping the experienced folks could help me out. Thank you
Leonidsg is offline   Reply With Quote
Old 09-10-2014, 03:41 PM   #2
Rewards Points: 18,376
Far easier to just add a wooden threshold and add the flooring in the other direction inside the closet.
oh'mike (09-10-2014)
Old 09-10-2014, 10:00 PM   #3
Rewards Points: 33
Can you elaborate on the threshold idea. I feel like putting a threshold on the end there will be too far out into the hallway and not located under the actual door.
Thank you
Lenny
Old 09-12-2014, 02:22 PM   #4
Rewards Points: 1,042
Putting a threshold out that far won't look right, and putting in a piece parallel will look odd also, best to just continue the run.
Canarywood1 is offline   Reply With Quote
Old 09-12-2014, 03:02 PM   #5
Rewards Points: 101
I disagree, I do not think a threshold wood look weird there...The wood going the other direction will be in a closet, so I would not be super concerned with the final "looks" of the closet floor as long as it is easy to clean/sweep. With a door in there it looks like you would only see a little bit of the threshold, which is perfectly normal. This is how I have it in my house where my tile bathroom meets the hardwood floor. The threshold is not "hidden" by the door 100%.
Agree with Joe, make it easier on yourself and put a threshold in and then some type of flooring and call it a day.
If you are not good with flooring it may be difficult for you to properly link the original and "closet" wood and you may end up doing more damage than good to those existing floors.
Thomas
South Jersey - Camden County
tjbingha is offline   Reply With Quote
The Following User Says Thank You to tjbingha For This Useful Post:
mnp13 (09-17-2014)
Old 09-12-2014, 06:59 PM   #6
This is how I have it in my house where my tile bathroom meets the hardwood floor . The threshold is not "hidden" by the door 100%."
You probably have a transition strip not a threshold, and he's not concerned about the closet side, it's the existing floor he's talking about, looks to be about 2 inches from the door from the pic, but could be less hard to tell from photo.
Old 09-17-2014, 09:39 AM   #7
Rewards Points: 33
That is correct I think there would be 2 or so inches to the actual door. I did also mean to say transition strip perpendicular to the current floor but you would then see that strip as well as the continuation of the floor into the closet. I can attempt weaving into the existing floor if you all have some guidance. One big issue I am trying to avoid is refinishing all of the floor because the weaved portion wont match. I dont have time to refinish the second floor. I was hoping on being able to temporarly blend it in, I don't know what the best way would be for that. I have a 10 month old so I am also trying to cut down on VOC, and other health related fumes.
Thank you for everyones input.
Old 09-17-2014, 01:30 PM   #8
Just continue the run to the closet side of the door casing, and your good to go.
Old 09-17-2014, 01:45 PM   #9
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
I agree, put a threshold perpendicular to the floor boards and then put in the closet door. Every room in my house that has a threshold has one that is the same depth as the door frame. It's not abnormal. If you don't feather in the boards (time consuming, not easy and will require very careful refinishing of that entire section of floor if you don't want to redo the whole room) it will look far more odd than having a door-frame-width threshold.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 09-29-2014, 03:40 PM   #10
Rewards Points: 33
Do you mind ellaborating just a bit more
When you say threshold do mean one that actually sits on top of the floor or do you mean placing the same hardwood perpendicular. Sorry if thats a dumb question
Thank you
Bedroom Closet Organizing trixie2396 Interior Decorating 10 09-19-2013 07:14 AM
Continuing a bedroom single pole switch/light to a closet single pole switch/light chadsunderman Electrical 3 06-09-2013 11:29 AM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 05:42 AM
