Concrete Grinding - Flooring - DIY Chatroom Home Improvement Forum
Old 06-09-2015, 04:18 PM   #1
Concrete grinding
I am having trouble removing black "cutback" adhesive from the slab of a room that is approx. 400 square feet. If I rent a concrete grinder will it knock this out? My concern is that the adhesive will clog the carbide teeth.
Sorry if this is a dumb question but I could really use some help.
Fromthehip is offline   Reply With Quote
Old 06-09-2015, 04:23 PM   #2
Rewards Points: 18,376
Hard to read your post, not your fault, just the way this site acts sometimes.
Guessing your asking how to remove black cutback adhesive.
Most likely it contains Asbostos.
I'd be using a Soy mastic remover.
Google it.
Old 06-10-2015, 06:20 AM   #3
Read up on Bean-e-doo. Will likely go that route. There is actually no asbestos. I had a company come take a sample and test it as soon as I saw the stuff. Considering that, is the remover still my best bet or would a scarifier or grinder be more effective?
Old 06-10-2015, 12:07 PM   #4
Rewards Points: 866
I just saw this and read it since I have a current similar post. You may want to look at some of the help the guys gave me.
If you like the idea of using a scraping bit and will be doing other floors in the future, I would look into buying a bit for about $80.
Klawman is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Concrete Basics for the DIYer Mort Concrete, Stone & Masonry 7 11-22-2012 12:19 PM
garden shed on existing concrete pad hartkem Building & Construction 6 10-27-2011 09:46 PM
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
