Concrete Floor Staining/painting DIY - Flooring - DIY Chatroom Home Improvement Forum
Old 04-26-2016, 09:12 AM   #1
Rewards Points: 2
Concrete floor staining/painting DIY
We were hoping to stain a concrete floor (after ripping up the carpet and carpet padding). However the concrete floor is painted. We were able to get up some of the paint but not all of it, and likely will not be able to get the rest of it up. I know we can paint the floor, but is there any type of paint we could use that we could then put a stain over it. I like the way a stained concrete floor looks better than a painted floor. Help Need suggestions.
eakidd01 is offline   Reply With Quote
Old 04-26-2016, 09:19 AM   #2
Rewards Points: 17,912
Re: Concrete floor staining/painting DIY
Just not going to happen, stain is just that, it's has to be able to soak into the slab, not just float on top of what ever was on it before.
Old 04-26-2016, 11:00 AM   #3
Rewards Points: 30
Why not use a concrete grinder on the floor to get rid of the paint for good? Remove high spots if it isn't level already then apply your stain to the floor. You can use different grinding wheels for different results.
motoriderx7x is offline   Reply With Quote
Old 04-27-2016, 05:52 PM   #4
Rewards Points: 4
You can rent a floor polisher and coating removal tool from homedepot. This will help to grind off the paint and any carpet glue left on the floor.
I did this last year when I removed vinyl tile and the adhesive from my concrete floors so I could stain them. It works very well, but is hard work.
Stultis is offline   Reply With Quote
Concrete shower floor and drain issue whoowl Kitchen & Bath Remodeling 0 07-24-2015 04:10 AM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
