Cleats Or Staples For Hardwood Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 03-13-2016, 11:03 AM   #1
Cleats or staples for hardwood installation
I'm going to be installing 3/4" x 3 1/4" white oak over 3/4" plywood subfloor. I bought a Numax flooring nailer/stapler. Manufacturer instructions say to use either staple or cleats. Is one better then the other ? Going to use a 2" either way.
Jmunk is offline   Reply With Quote
Old 03-13-2016, 11:13 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 17,888
Re: Cleats or staples for hardwood installation
I used cleats when I installed my solid bamboo.....and staples for my 1/2" solid oak (over 60 years old)
I think the cleats have slighter better holding power....and you can use a punch to sink one in a little deeper if it comes up proud. Cleats are a little less likely to split the tongue on the wood.
Since your wood is 3/4", I think you will be fine with either one.
But I'll be watching this to see what everyone else says.....
Kitchen and Living Room Installation bejscott Insulation 1 08-10-2012 12:18 PM
Laminate floor installation tomkk Flooring 6 02-17-2012 04:20 PM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
a few questions about bamboo flooring installation bostonmike Flooring 2 01-19-2008 08:06 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
