Ceramic Tile Install From Subfloor Up - Flooring - DIY Chatroom Home Improvement Forum
Old 03-10-2019, 09:44 AM   #1
Rewards Points: 12
Ceramic tile install from subfloor up
Hello All,
I have been waiting to do this small project for some time as expected to run into issues. Wife wanted tile in the bathroom. I am 90% done removing the tongue and groove wood flooring. It had laminate flooring on it. I was hoping that the wood would be ok but had mold. Like I said expected issues. So the wood needed to be pulled.
Found the installers put a vapor tar paper barrier in under the wood flooring. So that protected from the mold spread. Great!
I have never done tile before. I am now down to the floor planks across the floor supports. I got some Ditra to give more support. Do I need to install plywood over the planks then do motar, then Ditra then motar then the ceramic tile? Or can I just do motar then Ditra then motar to tile?
Not trying to cut corners, want to do it right while it's all open. I have the time on Vacation, just the wife's patience I am up against haha.
Also wondering if worth installing heater coils but never done that. Just was thinking since it was open. It's a small bathroom only 4x7.
Throwing in new sink and toilet while I am at it.
Sean1 is offline   Reply With Quote
Old 03-10-2019, 09:49 AM   #2
Rewards Points: 12
Here is the pre floor pull
Ceramic tile install from subfloor up-img_20190309_151756931_1552229350674.jpg
Old 03-10-2019, 10:40 AM   #3
Rewards Points: 4,760
Re: Ceramic tile install from subfloor up
Nope, Ditra is not structural.
Absolutely. How thick are the planks? What's the size, spacing and unsupported span of the floor joists? You said ceramic - you mean ceramic or porcelain and not a natural stone product, right?
stick\shift is offline   Reply With Quote
Old 03-10-2019, 10:53 AM   #4
Rewards Points: 12
Here is where I am at now. Yes, ceramic tile. The sub floor is 10in boards as you can see. 3/4 to 1in think. Beams are 16in o/c to 10in o/c house is oldish 1940's
Ceramic tile install from subfloor up-img_20190310_114256353_1552232727478.jpg   Ceramic tile install from subfloor up-img_20190310_114326309_1552232736475.jpg   Ceramic tile install from subfloor up-img_20190310_115005327_1552233074921.jpg
Getting creative replacing ceramic tile tojo78 Tiling, ceramics, marble 4 03-20-2016 07:07 PM
Is glazed ceramic tile permeable to vapor? Pamp81 Flooring 19 06-28-2013 02:36 PM
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 09:56 AM
install outlet through existing tile? hoosadam Electrical 3 02-01-2011 12:47 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 06:08 PM
