Ceramic Tile Glue Removal - Flooring - DIY Chatroom Home Improvement Forum
Old 11-18-2013, 11:12 AM   #1
Rewards Points: 740
Ceramic tile glue removal
I need to lift up some ceramic tile. It is easy to break the tile, but I am left with the glue or grout that is hard as a rock. How do I make my floor clean and flat so I can apply new flooring? Is there a tool of some kind? Thank you in advance to all who help.
crescere is offline   Reply With Quote
Old 11-18-2013, 12:30 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
Depends on whats underneath the tile. If its wood subfloor, rent an SDS hammer with a chisel bit and/or scraper bit. You can take up everything at once. If over concrete, the same thing will work to get most of it up, but you may need to spend some time with a grinder and a diamond cup wheel.
iminaquagmire is offline   Reply With Quote
How to remove ceramic tile that was installed over marble hex tile? bam42 Tiling, ceramics, marble 1 01-15-2013 12:59 PM
ceramic tile over OSB snowchild Flooring 26 12-08-2012 11:50 AM
Premixed Tile Adhesive Removal - Need Help bassheadjohn Kitchen & Bath Remodeling 4 09-07-2012 12:58 PM
Problem with concrete floor prep for ceramic tile install tdon7 Flooring 8 11-30-2011 11:12 PM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
