Cement Floor On Plywood - Flooring - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 12:52 AM   #1
Cement floor on plywood
Our home is built on post and pillar and under the carpet has plywood. We really wanted our kitchen/dining room to have painted cement flooring though. Has anyone done this before or have thoughts on if it would be easy to almost putty on cement instead of pouring a whole slap of cement flooring down?
praisegod4 is offline   Reply With Quote
Old 09-19-2011, 07:05 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
Very little chance of success putting concrete on plywood. Any movement at all will cause cracking.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-01-2011, 03:53 PM   #3
General Contractor
SeattleSurfaces's Avatar
There are several polymer modified concrete products that can be used for an application like this, but the process is pretty intricate, and you have to have a good understanding of your products and the structure to make sure it won't fail.
Typically, you would use a tar paper over your plywood, staple a metal lath to the framing and floor, apply a scratch coat and then top coat depending on the finish you are desiring. I wouldn't recommend painting concrete at all ever! At the least use a high quality concrete epoxy.
This is a stamped concrete floor that flushed up with the 1/2" engineered hardwoods in the hallway.
SeattleSurfaces is offline   Reply With Quote
Old 10-01-2011, 08:21 PM   #4
Rewards Points: 398
I don't think that process is recommended by any reputable organization.
Old 10-01-2011, 08:36 PM   #5
General Contractor
I know several reputable organization that would say otherwise, but because you say so, I guess that makes it so, champ.
gravel tar roof repairing mazizbit Roofing/Siding 7 04-09-2012 10:52 AM
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-25-2011 12:58 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 09:32 AM
