Caulk Gap Between Kitchen Wood Floor And Sheetrock To Protect Against Roaches - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By chandler48
Old 05-17-2018, 06:49 PM   #1
Rewards Points: 672
Caulk Gap between kitchen wood floor and sheetrock to protect against roaches
Im installing kitchen cabinets and Iím wondering if i should caulk b/w the wood floor and the sheetrock. MY condo building doesnít have any roaches or mice, but you never know who youíre next neighbor will be.
Will the caulk allow for expansion of the wood floor? I left gaps for expansion as per the wood flooring manufacturers guidelines.
jaketrades is offline   Reply With Quote
Old 05-17-2018, 07:01 PM   #2
Guapo
Rewards Points: 11,950
Re: Caulk Gap between kitchen wood floor and sheetrock to protect against roaches
It can't hurt to caulk it but if there are roaches in the building, they will find a way to enter, probably around the pipes. I'm in a rental & exterminators come once a month. They put a dab of some gel on a few hinges & a dab under the bathroom sink. A little dab 'ill do ya. There is no smell & I haven't seen any insects.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
jaketrades (05-18-2018)
Old 05-17-2018, 09:09 PM   #3
Rewards Points: 368
I agree with the other response. It won't hurt, but I don't know that it would be very effective.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Old 06-08-2018, 04:17 AM   #4
Rewards Points: 6
Hope you were able to work out on the caulk
miketan is offline   Reply With Quote
Old 06-08-2018, 04:25 AM   #5
retired framer
Rewards Points: 14,706
roaches are like water they will find a way.
Old 06-08-2018, 04:45 AM   #6
Naildriver
chandler48's Avatar
Rewards Points: 2,506
There's no "gap" at the bottom of the sheetrock as it is tight to the bottom plate. I agree with the others. They are coming in around pipe openings and other small gaps in the wall. Sprinkle Borax in the area. It won't kill them, but it will make them go to your neighbor's house. They enter your house for one reason........food. Clean things up and seal all food items and they will have no reason to enter.
jaketrades likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
jaketrades (06-08-2018)
