Cat Pee Soaked Pad Stuck To Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 02-09-2018, 06:44 PM   #1
Rewards Points: 86
Cat Pee Soaked Pad Stuck to Hardwood Floor
Evening all,
I started demo on a house I am flipping today and when we pulled up the carpet the pad has basically fused with the hardwood flooring. I spent an hour or so with a putty knife and got some but there are huge areas where it's not making a dent. Anyone have any ideas on how to handle this?
YesHaveSome is offline   Reply With Quote
Old 02-09-2018, 11:53 PM   #2
Peace be with you
DR P's Avatar
Rewards Points: 1,860
Re: Cat Pee Soaked Pad Stuck to Hardwood Floor
was on a remodel once & witnessed the house flipper reworking the old wood flooring with simple green... worked on the urine stains, greases, cleaned, even deodorized all at once... basically he gave the old wood floors a facelift without having to strip/sand refinish... was it perfect - nah; did it look great after compared to the before? you bet... that said, I can not truly speak/swear that it will easily remove you situation; but seeing as this product is about as friendly to use as you are going to find, what have you got to loose?
http://simplegreen.com/products/all-purpose-cleaner/
Peace
My comments towards your questions & concerns are based on my work history, knowledge, & past experiences; they are my opinions given freely in hopes they truly help/bless U. That said, if U don't consult with & or hire a licensed professional locally, then please don't blame me when You DIY... Bottom line - Safety 1st & Always; got that???
DR P is offline   Reply With Quote
Old 02-10-2018, 08:05 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Ayuh,.... How 'bout an air powered scraper,..??
Old 02-10-2018, 08:36 AM   #4
JUSTA MEMBER
Rewards Points: 4,038
Another vote for Simple Green.
Soak it in S G, and wait a half hour , then try to scrape it.
This stuff is amazing, and environmental friendly.
ED
de-nagorg is online now   Reply With Quote
Old 02-10-2018, 09:01 AM   #5
retired painter
Rewards Points: 1,790
I'd be concerned with any urine that has soaked down between the pieces of hardwood.
joecaption likes this.
mark sr is online now   Reply With Quote
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 05:15 AM
Hardwood floor is buckling again Kerm Flooring 1 05-07-2010 05:35 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 06:53 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 10:20 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
