Cast Iron Radaitors On Laminate Floors ? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 09:20 PM   #1
Cast iron radaitors on laminate floors ?
I recently laid some laminate floor down in a spare bedroom and I am very pleased with it the problem is I would like to do some other rooms in the house but there are large heavy radiators in these rooms the house was built in the 40s . If anyone has delt with this I would appreciate there input
ants1929 is offline   Reply With Quote
Old 01-23-2012, 09:22 PM   #2
mike owes me $53 dollars
Tech Dawg's Avatar
Steam or hot water...??
Todd
www.aloneeagle.com
Tech Dawg is offline   Reply With Quote
Old 01-23-2012, 09:24 PM   #3
Steam but I don't have any leaks every thing is an good shape
Old 01-23-2012, 09:27 PM   #4
Tech Dawg's Avatar
That's good. Just shut off the gate valve and un bolt it... Make sure that you have some play in the pipe. Usually your new finished floor height has to be the exact height as the old one to get your radiator back in
Todd
www.aloneeagle.com
Old 01-23-2012, 09:33 PM   #5
Ok great the stuff I am using is 8mm my concern is would the radiators damage the floors from there weight
Old 01-23-2012, 09:45 PM   #6
Has anyone installed laminate with this issue and had damage from the weight of large cast iron radiators
Old 01-27-2012, 07:59 PM   #7
Has any one experienced damage issues with laminate floor and the weight of cast iron radiators
Old 01-27-2012, 08:04 PM   #8
Rewards Points: 18,384
Not damage the flooring but it will pull apart when it trys to exapnd and contract.
What's on the floors now? If it's hardwood then refinished it.
Old 01-30-2012, 07:23 PM   #9
I was worried more with the weight sinking impression In the planks and maybe pulling them up
Old 01-30-2012, 07:51 PM   #10
There super hard and dence and not likly to dent, but they will pull apart from the weight.
An engineered flooring floor would work.
Old 01-30-2012, 07:53 PM   #11
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They make matts for wood stoves/radiators.
titanoman is offline   Reply With Quote
Old 01-30-2012, 08:45 PM   #12
That's sound like a good idea any info on who makes them or were to purchase
Old 01-30-2012, 10:09 PM   #13
Disabled wood vet
titanoman's Avatar
Start with a fireplace/woodstove outlet. That's where I've seen them.
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 05:41 PM
Dealing With old large cast iron radiators and new floors ??? ants1929 Flooring 4 02-12-2011 09:40 AM
cast iron radiators on laminate floor klally Flooring 0 11-04-2010 09:09 PM
Cast Iron Radiators and Laminate, Help! Cole_33 Flooring 0 07-21-2010 11:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
