Carpet Underlay.... How Thick..... - Flooring - DIY Chatroom Home Improvement Forum
Old 10-18-2014, 09:46 PM   #1
Bob Sanders's Avatar
Rewards Points: 2,536
Carpet Underlay.... how thick.....
How thick can you go without getting into trouble? I think the standard is 1/2 inch.... can you go 3/4 or 1 inch, and what would happen if you did?
Bob Sanders is offline   Reply With Quote
Old 10-18-2014, 11:31 PM   #2
Rewards Points: 17,912
Are you talking about carpet pad, or underlayment.
Two completely different things.
Old 10-19-2014, 06:09 AM   #3
Sorry, carpet pad.
Old 10-19-2014, 08:43 AM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,632
The carpet would not wear right and would most likely wrinkle. You would shorten the life of the carpet and void all warranties.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-19-2014, 08:49 AM   #5
Any reason your thinking you need it that thick?
Old 10-19-2014, 09:29 AM   #6
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Industry standard has been 7/16 for a long time now. 3/8 is commonly used on lower pile carpet. I'd be more worried about density and construction that getting a thicker pad. Go with a 8lb or higher pad. You might even want to step up to a memory or urethane foam if you want the best out there.
Darkling Designs
poppameth is offline   Reply With Quote
Old 10-19-2014, 12:48 PM   #7
No.
We're going with standard 1/2 inch. I was just curious.
Old 10-29-2014, 01:14 AM   #8
Rewards Points: 108
If you are talking about carpet pad or foam, then 10mm Thick Carpet Underlay Roll is good.
RobertCurry is offline   Reply With Quote
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 09:20 AM
asbestos problem under glued down carpet lisacolin Flooring 7 01-12-2011 02:34 PM
Need help with installing carpet tack strips proofer Flooring 5 05-24-2008 05:51 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
