Carpet Tile Install - How Much Carpet Needed - Flooring - DIY Chatroom Home Improvement Forum
Old 02-21-2014, 03:08 PM   #1
I am thinking of installing Carpet Tiles in my office.
I am looking at a Carpet Tile product by TrafficMaster from Home Depot.
The description of that product says the Carpet Tile is 19.7in x 19.7in - and that there are 20 tiles per case. It then goes on to say the total coverable area is 54 Sq Ft.
How exactly do they arrive at the number of 54 SF? My math does not agree with their math.
Each individual tile is approximately 1.58 SqFt in coverage area - and if you lay the tiles out in a big square of 10 tiles wide by 10 tiles long - you will have 15.8 x 15.8 SF covered - or approximately 250 SF of total area covered by that case of 20 tiles.
Please let me know what I am doing wrong.
laawaaris is offline   Reply With Quote
Old 02-21-2014, 04:07 PM   #2
Rewards Points: 18,384
Your forgetting to divide by 12 to convert from sq. inch's to sq. ft.
Comes out to 53.90 Sq. feet per box.
Always add at least 10% for cuts.
rusty baker (02-21-2014)
Old 02-21-2014, 08:03 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 780
I'm not sure how you came up with 1 tile = 1.58 sq. ft. Each tile = 2.6950694 sq. ft. or as Joe said 53.90 for a box of 20 pcs.
Oh, I know what you did with the 1.58. 19.7" is 1.58 linear ft. and so you decided that's is was sq. ft. You should have multiplied 19.7 x 19.7 =388.09 - then divided by 144 which = 2.695 x20 etc.
p.s. I've seen those carpet tiles and they look pretty thin to me. Might be too cheap?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-22-2014, 08:51 PM   #4
Thanks for your help guys - I understand what you are saying and see now what I have done wrong
Old 02-22-2014, 09:03 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 17,746
Now that you have the area figured out.....don't do it.....
I've used them.....looks ok at first....but....if a corner pulls up...dirt gets under it...then it won't stay down.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
joecaption (02-22-2014)
Tile to carpet transition BlueBSH Flooring 5 03-21-2013 01:26 PM
Floating hardwood transitions to carpet and tile adefields Flooring 2 11-21-2012 12:39 PM
Carpet Tile and Baseboard Installation TheMadStrater Flooring 1 12-29-2011 10:44 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
