Carpet Seams - Flooring - DIY Chatroom Home Improvement Forum
Old 05-23-2015, 01:04 AM   #1
Rewards Points: 452
carpet seams
Somewhat high traffic hallway has loose carpet that needs to be restretched, cut, then re-seamed.
Now, how durable is the self stick tape?
pman6 is offline   Reply With Quote
Old 05-23-2015, 09:27 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
It won't hold up to heavy foot traffic.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 05-24-2015, 06:59 AM   #3
Rewards Points: 452
Can you cut a seam at an existing seam location, or do you have to find another place to cut?
If I stretch the carpet, the best place to cut and pull excess is at the doorway, but I think the doorway is already a seam.
Old 05-24-2015, 08:08 AM   #4
Rewards Points: 109
Yes, a seam can be cut and reseamed but the old glue/tape needs to be pealed off. The edges on both sides will need to be recut straight and then reseamed. You can glue over the existing glue otherwise you will feel the lump when you step on it. Only way it works if if you have enough slack in carpet to cut the seam and about 1" from both sides of. Carpet to be seamed so it can be restretched to make a new good seam
Olcrazy1 is offline   Reply With Quote
Old 05-24-2015, 08:20 AM   #5
Rewards Points: 398
The old tape needs to be reheated from the back with a seaming iron to remove it. If you just peel it off you will damage the backing.
Old 05-24-2015, 10:51 AM   #6
Rewards Points: 109
Agreed,I should have mentioned that, to peal off old glue utmost be reheated
Old 05-25-2015, 11:43 AM   #7
Rewards Points: 5,010
Where are the doors located in the hallway.?
Stretching alone will not work in a hall with doorways unless it's one door at the end.
You could make new seams and stretching the carpet between doorways without pulling too much making the cut appear in the opening. You would have a fighting chance by installing new padding, then stretching along with new seams.
ron45 is offline   Reply With Quote
Old 05-25-2015, 12:08 PM   #8
Rewards Points: 398
Restretching a hallway is not really a DIY project anyway. It can get complicated.
Old 05-26-2015, 07:53 AM   #9
Rewards Points: 452
see, it's worse now. the ripples. And the doorway already has a seam
Old 05-26-2015, 08:10 AM   #10
Rewards Points: 398
That would be a difficult job.
Old 05-26-2015, 03:18 PM   #11
Rewards Points: 452
damn. I was hoping I could pull the loose carpet toward the doorway and re-seam at the doorway
Old 05-26-2015, 03:29 PM   #12
Rewards Points: 398
Looking into the doorway, the carpet needs to be stretched to the right and left. With those corners, it would be a difficult DIY job.
Old 05-26-2015, 05:41 PM   #13
Rewards Points: 452
Here's another view from outside the doorway.... same opinion?
Old 05-26-2015, 09:23 PM   #14
Rewards Points: 398
It would not be easy.
carpet seams fgunternahrer Flooring 1 04-16-2013 03:01 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
