Carpet Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 06-07-2015, 08:34 PM   #1
Rewards Points: 590
carpet repair
We want to put our house on the market in the next couple years and we already need a new ac unit and roof so we want to fix some cheap cosmetic issues. Is it possible to fix this carpet damaged by a cat we used to have?
nikeman is offline   Reply With Quote
Old 06-07-2015, 09:40 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,652
If you have scraps or maybe could get a piece out of the back of a closet. You would really need a pro to do it so it wouldn't be obvious though. That repair would not be easy.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-07-2015, 09:48 PM   #3
Rewards Points: 590
I'm pretty sure I have extra carpet but what would the process be? Cut a small portion from the new and glue it down?
Old 06-07-2015, 11:11 PM   #4
Rewards Points: 4,414
I had an apartment manager ask me how to get kool-aid out of carpet, so I told him. The next day he called me to do a carpet repair, he had burnt the face of the carpet.
You will need either a hot steaming iron or a carpet seaming iron......
ron45 is offline   Reply With Quote
Old 06-08-2015, 08:52 AM   #5
You could try that, but without experience, it may not look great.
Old 06-08-2015, 05:34 PM   #6
Rewards Points: 590
I found something online that says to use a can to mark a circle around the area and cut it out with an exact knife. Then use the same can and cut out a circle in the new carpet. Then put carpet tape in the hole and under the existing carpet and put new carpet in hole and apply weight for several hours. Sounded and looked feasible to me. What do you guys think?
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
When to install base molding? h22lude Flooring 34 03-14-2015 04:02 PM
Quarter Round with New Carpet ryanb4614 Flooring 4 11-21-2011 09:20 AM
Carpet - different colours in 2 rooms tonyt Flooring 1 09-09-2007 04:21 PM
