Carpet On Grade Level Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 07:58 PM   #1
Carpet on grade level concrete slab
I am mulling my options for flooring on a converted concrete slab at grade level (garage coverted in the 70's). Carpet seems easiest and cheapest. There was a carpet previously(before I ripped out a few years ago) there and I have not noticed any moisture at all. Is carpet a bad idea? If not, how should I prep the concrete for carpet? Thanks!
JRP_24 is offline   Reply With Quote
Old 06-18-2011, 09:04 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 730
If no moisture, no prep is needed.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Can I use my existing concrete slab for flooring... Somerichs Flooring 4 01-17-2011 11:20 AM
lifting up concrete slab ctudan Building & Construction 1 10-28-2008 02:44 PM
Finishing Basement, carpet install order? tigerbalm2424 Flooring 33 07-24-2008 08:35 AM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
