Can I Reuse Old Baseboards - Flooring - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 07:14 PM   #1
Rewards Points: 83
Can i reuse old baseboards
I'm planning on pulling up the carpet in my bedroom and staining the concrete. To save money I wanted to reuse the base boards. since I'm going to be lowering the floor will I have to buy new boards so that the unfinished walls behind the boards don't show?
ttwin is offline   Reply With Quote
Old 04-11-2014, 07:26 PM   #2
Retired Moderator
Rewards Points: 7,174
How large is the gap? If a shoe molding will hide the gap--simply add one---
Old 04-11-2014, 07:55 PM   #3
Rewards Points: 83
Sorry I worded that wrong. If I remove the base boards to paint the trim when I place the trim back on will it hide the TOP of the unfinished wall. Or will I need TALLER trim to hide that?
Old 04-11-2014, 08:06 PM   #4
Retired Moderator
Unless the old base boards are of fine quality--it will be better and cheaper to replace them.
After you remove the old ones,there will be a paint/caulk line---if you lower the original ones,that paint line will need to be filled----and the walls repainted---
Also? are the old moldings going to look good after they have been removed?
Old 04-11-2014, 08:42 PM   #5
Rewards Points: 83
Unless the old base boards are of fine quality--it will be better and cheaper to replace them. After you remove the old ones,there will be a paint/caulk line---if you lower the original ones,that paint line will need to be filled----and the walls repainted--- Also? are the old moldings going to look good after they have been removed?
I'm not sure what you mean by "look good". I planned on painting the walls as part of the remodel.
Old 04-11-2014, 08:47 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
You can cut the caulk(if there is any)with a razor knife and pull the nails out from the back of baseboard with pliers then install the baseboard back in the exact same place and put 1/4 round on the bottom between baseboard and concrete to fill the gap if is not too big.
Attachment 83691
Robpo is offline   Reply With Quote
Old 04-11-2014, 09:07 PM   #7
Rob
Robpo's Avatar
Rewards Points: 826
New Carpet over hardwood with existing baseboards denovo Flooring 2 04-23-2012 10:01 AM
Should new baseboards go on top of carpet? hawks81 Flooring 4 08-23-2010 11:25 AM
Masking off baseboards 2 PaintedSurface Painting 1 01-18-2010 04:30 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 05:52 PM
Click lock floors under baseboards ? bcarwell Flooring 4 03-30-2008 11:03 PM
