Building Up Floor - Flooring - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By jlhaslip
  • 1 Post By GrnMtnDIY
Old 03-24-2017, 09:46 AM   #1
Rewards Points: 12
Building up floor
So here's the deal......
We have a walk-out basement and unfinished concrete floors right now. the portion where you walk-out was a sun porch that was not included in the square footage of our home until I ran heat into it. This sun porch currently has a slab with 2-1/4" red brick on top of it to support the completely awesome (not at all) hot tub. The slab for the rest of the basement is actually that 2-1/4" higher than the slab in the sun porch. Also, we are in the northeast (almost Quebec).
Here's how I am building up the floor:
ripping some 2x PT sleepers, gluing and screwing to the concrete, and putting the 5/8" (or 3/4") subfloor on top of those, thus getting the whole basement floor up to the same level.
My two questions: Does this seem like a logical route? And, Should I insulate, and if so,any recommendations for insulating between the sleepers (I was thinking 1" rigid) ?
Thanks in advance
GrnMtnDIY is offline   Reply With Quote
Old 03-24-2017, 10:13 AM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Building up floor
Sounds like a sound suggestion, but I do not understand the need to rip material.
Lay some pressure treated material on the flat and drop some 3/4 inch plywood on top to get the 2 1/4 inch required depth.
Is there any slope to this slab?
I have done this for basements and included shims to level the subfloor. Drilled and inserted nails which wedge into place.
https://www.concretefasteners.com/co...-nylon-nail-it
As for insulation, tough call. I am sure Bud or Gary will be along shortly to specify some detail to follow. They are the resident experts on this aspect and I defer to their judgement.
de-nagorg likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-24-2017, 10:34 AM   #3
Rewards Points: 12
Thanks - I was going to rip it down to save on material cost (225 sf area), as this project has a substantial budget due to the wrongs committed by previous owners.
(BTW - Edmonton was my previous home, and I still work remotely for my employer up there- Very underrated city
jlhaslip likes this.
Building new room in old barn, sagging floor pdjanson Building & Construction 6 11-10-2015 12:52 AM
Mid span bridging lylsutherland Building & Construction 2 10-29-2012 11:10 PM
Building a shed with a wood floor directvman Building & Construction 17 09-18-2012 09:26 AM
Ceramic Tile Floor Info Help RichardZ Tiling, ceramics, marble 36 07-26-2012 08:33 PM
Building New floor above Foyer matgol Carpentry 2 09-02-2008 04:58 PM
