Bugman Has A Flooring Question - Flooring - DIY Chatroom Home Improvement Forum
Old 09-11-2015, 03:28 PM   #1
Rewards Points: 105
Bugman has a flooring question
Perhaps I can hijack this thread with the following related questions of my own:
1.) Can someone recommend a good electric back-cut saw to use on the case molding?
2.) For transitioning from a hardwood hallway to a carpeted bedroom, I would like to just turn a piece of hardwood sideways to be perpendicular to the hardwood. The bedroom carpet was cut long when it was installed to allow this. So, do I just re-cut the carpet enough to fold under itself? I heard some guys will cut one lip of the groove to allow the carpet to kind of tuck under the remaining lip.
3.) What kind of sander is best? I've seen drum sanders that cause ruts because the guy doesn't keep it moving. So, is the vibrator the best?
4.) After sanding, do most add the sawdust to the filler and then spread?
Bugman1400 is offline   Reply With Quote
Old 09-11-2015, 03:51 PM   #2
Rewards Points: 5,348
Start your own thread as this leads to confusion.
Ron
B. Franklin 1759
Bugman has a flooring question oh'mike Flooring 0 09-11-2015 07:51 PM
Question on Acid Wash Flooring in Basement? Jim Ignatowski Flooring 0 07-24-2013 12:32 AM
Kitchen Flooring Question bcboy4ca Flooring 2 12-04-2012 11:51 PM
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 02:48 PM
new construction flooring question bgabrielse Building & Construction 5 12-05-2010 05:52 PM
