Bruce Hardwood 3 1/4 X 3/4 - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 08:34 AM   #16
Rewards Points: 1,280
Well, I have 240 sq ft to install
Like I said, the room is not that big, and relatively square
I am comfortable with laminate, but not with solid hardwood – I’ve never installed this type of flooring
The cheapest installer I found will take something like $700, which is may be a fair price but still expensive for my budget
This is why I thought I could try to do it…..but after reading all the answers in that post, I am a little scared to go ahead: I don’t want to mess up everything !!!
By the way, somebody said I could buy a flooring nailer at Harbor Freight for something like $150……I saw at my local Lumber Liquidator, they sale one (nailer/stapler) for $110
Anyway, 24h00 rent is $39 at Home Depot…..So I am still saving if I rent 2 days, but it’s better to buy at LL if I need it more than 2 days !!!
Bruce hardwood 3 1/4 x 3/4-floor.jpg
french_guy is offline   Reply With Quote
Old 05-23-2013, 09:33 AM   #17
Rewards Points: 91
I bought a reconditioned bostich flooring nailer on ebay for dirt cheap, installed the floors I needed then unloaded it on ebay when done, cost me about 20 bucks in the end... make sure you use a compressed air version.
tjfslaughter is offline   Reply With Quote
Old 05-23-2013, 11:16 AM   #18
If having a control line is so important, I will use the current planks already in the doorway as a reference and will snap a line from that reference (and I will need a spline since the groove is facing the carpet)
OR
I don’t try to “link” the new hardwood with the current one: I leave a gap and will have to put a transition bar……
Other question: how much expansion gap do I need to leave all around the room?
Old 05-23-2013, 11:20 AM   #19
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 790
OR
For a floating floor application, technically your expansion gap is a function of your product and size of the install (consult manufacturer specs recommendation ). Usually 3/8 inch is fine.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-23-2013, 11:51 AM   #20
So no need of gap at all for a nailed down application?
Old 05-23-2013, 11:56 AM   #21
Rewards Points: 790
Correct... Don't pound it in agaist your framing (sole plates) but no distinct gap required.
Old 05-24-2013, 10:19 AM   #22
So here is my layout
Based on what you all said, I think I will have to measure and report the width of the planks (3” ¼) from the last row, near each side of the door way
Then chalk a line based on these 2 marks, and it will be my starting line – I may have to trim the planks that will go against the wall (each side of the doorway)
For the expansion gap all around the room, how much should I put?
Bruce hardwood 3 1/4 x 3/4-layout-1.jpg   Bruce hardwood 3 1/4 x 3/4-layout-2.jpg
Bruce hardwood floors jjones1020 Flooring 5 04-20-2013 03:00 PM
Hardwood flooring installed with Bruce EVERBOND BobHorn Flooring 8 01-21-2013 08:46 PM
Hardwood floor BRUCE E550 french_guy Flooring 10 12-05-2012 04:05 PM
bruce hardwood margras5 Flooring 1 07-29-2010 10:51 PM
Bruce hardwood floors Andy in ATL Flooring 2 12-04-2009 08:49 PM
