Brocken Vct Tiles, Glue? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-18-2017, 08:46 AM   #1
Rewards Points: 294
Brocken vct tiles, glue?
I have 4 broken vct tiles that I need to replace. Is there a glue in a tube I can use in my caulk gun to set the tiles?
Mikeron is offline   Reply With Quote
Old 03-18-2017, 04:51 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,632
Re: Brocken vct tiles, glue?
The adhesive needs to put on really thin. They are supposed to be installed with pressure sensitive adhesive, but I have used multi-purpose to replace a couple. Need to keep weight on them while they dry if you use multi. If you use pressure sensitive, it is allowed to dry before the tiles are installed.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
What Adhesive to glue Tiles over Brick? cody21 Building & Construction 1 10-23-2012 02:27 PM
loose tiles in bathroom exodus125 Tiling, ceramics, marble 1 05-10-2010 07:43 PM
Asbestos Tiles and Red Glue Roadrunner Flooring 7 01-18-2010 07:54 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 06:29 AM
Old Tiles Removed - Now What?!?! Pineapple Flooring 5 10-14-2008 12:02 AM
