Best Way To Pour LevelQuik RS - Flooring - DIY Chatroom Home Improvement Forum
Old 01-21-2014, 05:35 PM   #1
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Best Way to Pour LevelQuik RS
Hi all,
I need some help figuring out the best way to pour LevelQuik RS. I have a 45 square foot basement bathroom Iím building and need to add 1 inch of SLC. Iíve done a bunch of research already and realize I need to do it in a single pour instead of doing 1 bag at a time because it will harden too quickly. A single bag is supposed to cover 45 square feet at 1/8Ē thickness. This means I need 8 bags of LevelQuik to get an inch of thickness. I was planning on getting a 20-gallon trash can to do the mixing. If my calculations are correct I need 13 gallons of water (6.5 quarts * 8 = 13 gallons) for 8 bags of LevelQuik. Will 13 gallons of water and 8 bags of LevelQuik fit in a 20 gallon trashcan? If it does, that will be about 400 lbs. I can mix it right next to the bathroom so itís juts a matter of tipping it over, but that seems like a lot of weight for a plastic trash can. Has anyone mixed that many bags in one pour? The instructions also say I can do several single pours where I wait 2-4 hours between. Would that be a better way? Has anyone done pours like that before? BTW, Iíll be following all the instructions and priming as required. I also have a pretty heavy duty drill I can use, but still concerned that Iíll be mixing 400 pounds of material with the drill.
Any feedback would be appreciated.
Thanks,
Jon
jonhayden is offline   Reply With Quote
Old 01-21-2014, 06:42 PM   #2
Retired Moderator
Rewards Points: 7,174
You can't do a single pour---read the label--I believe 1/4" per pour is about the limit-
I don't use that brand--however they all seem to have similar instructions.
Old 01-21-2014, 06:44 PM   #3
Rewards Points: 9,384
Being an amateur who has only used SLC once, I can give only limited advice, but what I will tell you is:
1) Self Leveling Compound is not self-leveling. It is almost self leveling. You need to give it some help with a rake or other. Maybe some brands are less viscous than other.
2) I thought my drill was heavy duty, then it started smoking as I mixed. Don't get the expensive mixer with the big paddles, get the cheap one that only has 1/4" rods to mix.
3) The way you word your post, it rather sounds like you are trying to raise the floor, rather than level it. Might be a better way.
SPS-1 is online now   Reply With Quote
Old 01-21-2014, 07:06 PM   #4
Want to Learn
jonhayden's Avatar
Rewards Points: 157
From the instructions:
"This quick- setting underlayment can be applied to 1" (2.5 cm) thick in one pour and seeks its own level in minutes."
Old 01-21-2014, 07:14 PM   #5
Retired Moderator
Got you---I sure haven't the nerve to try that---
I have mixed sand with the first coat to stretch the product--I use Jifset mostly--
If Jazman comments--listen to his advice---
I would do several pours--easier to control---
Old 01-21-2014, 07:14 PM   #6
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Yep, I have an 18" squeegee I'm going to use. I plan to cut out some notches in it to help spread it.
I think I have the cheap one you're describing. I used it to mix drywall compound.
Exactly! Also to embed the electric radiant heating wires. The adjoining bedroom is 1" higher due to the added subfloor so I have to raise it up. It's probably fairly level already. SLC just seemed easier than using regular concrete.
Old 01-21-2014, 07:19 PM   #7
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Thanks Mike! Several pours might be the way to go. It says you can do a second pour after a couple hours when it's hard enough to walk on. And you don't need to re-apply the primer in that case. And the first pour can be a practice pour too and if I screw up and it's lumpy I still have a second pour to cover up the mistakes. Plus might be easier on my drill
Old 01-21-2014, 07:45 PM   #8
Retired Moderator
The stuff is rather soupy so mixing it is not to rough on your drill----
Old 01-21-2014, 07:57 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 780
Hi guys,
A #50 bag equals a 5 gal. bucket to the rim. If you have help you might try 3 bags at a time, (?) but no more. But then you have no experience.....so?
I would mix one at a time in 5 gal. pail but be ready with several pre-measured amounts of water, and work fast. "RS" stands for rapid setting.
I think I would do this in at least 2 pours. Save the last bag or two for after what's been poured has set up so you can determine how flat it is and isn't.
I don't think a squeegee will be the main tool. A small plastic rake like an old shag carpet rake, even a garden rake works better. Be sure to plug any crack and dam the doorway.
OR..............
You can spread pea-gravel to make bulk and use a lot less SLC. 1/2" - 3/4" pea +-
OR............
You're gonna spend about $250 for the SLC alone, plus primer and odds & ends. Why not do or hire someone to do a "mud" job for you? Sand Topping Mix + several bags of sand might cost $40-50.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-21-2014, 08:21 PM   #10
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Thanks for the detailed response
Originally Posted by JazMan View Post
Hi guys,
Wow, good to know. So Maybe I'll do 3 bags at a time with a few hours in between for a total of 3 pours.
So you wouldn't suggest doing 3 bags plus water in a 20 gallon container? I keep reading that doing a 5 gallon bucket at a time might not give enough time to work with it.
My reasoning for not using a rake is I'll have loose heating wire wrapped and glued all around the floor for the under ground heating. I don't want to pull up a wire. I'll be caulking and damming EVERYTHING.
This sounds interesting. Do you think that would be okay with the heating wire and not damage it? Will the pea gravel stay put and not float up to the surface? What about the SLC needing the primer to stick too...won't that interfere?
Yeah, I already figured out the cost of the SLC But it seems like any time I get a quote for someone to do something it's at least a $1000. Nothing in my area is cheap. I recently moved the rough-in plumbing, passed my inspection, and filled back in with concrete. That cost me about $100 to do. I was quoted $1800 by a plumber to do that.
Thanks again!
Jon
Old 01-21-2014, 08:23 PM   #11
Want to Learn
jonhayden's Avatar
Rewards Points: 157
That's good to know. Thanks!
The Following User Says Thank You to jonhayden For This Useful Post:
oh'mike (01-21-2014)
Old 01-21-2014, 09:01 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 780
Jon,
If you wanna do 3 bags in the 20 gal, that's a good plan. I'm not used to pouring 1" cuz I would use mud.
Whether you mix one or three, you have to have the water ready, mix for 2 min. and dump. Water in the bucket first then add powder, of course.
Yea, a rake could mess up the wires, so, just pour the first batch, then you can use a metal rake once the wires are buried.
If using pea gravel you prime before placing it. However, be sure the gravel is the washed type. There's info on that someplace. I would do a thin pour, then place the gravel, then more SLC. Or just skip the gravel and just use SLC. It's only money.
A good mudman should be able to do the work in a few hours. It'll end up taking most of the day by the time he gets everything on the job and set up. I think $400-500 is doable. Another option is for you to do the mud and then tweak the surface with 2 bags of SLC at most.
Jaz
Old 01-21-2014, 09:04 PM   #13
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Jaz,
Thanks so much for your help. Great idea about using the rake after the wires are buried. I'll do that.
Thanks!!
Jon
Old 01-21-2014, 09:52 PM   #14
one more thing......
4) Use very cold water when mixing. That will slow down the time to set.
Old 01-21-2014, 10:08 PM   #15
Want to Learn
jonhayden's Avatar
Rewards Points: 157
Thanks! I've read that before. Thanks for reminding me.
Jon
To pour concrete ove asphalt or not to pour concrete over asphalt. murph2255 Concrete, Stone & Masonry 15 03-10-2013 08:25 AM
How do I pour an in-ground concrete tub? tibberous Concrete, Stone & Masonry 25 10-03-2012 10:42 AM
LevelQuik to raise basement bathroom floor height jonhayden Flooring 8 06-29-2012 09:55 AM
Monolithic Pour Jim Hart Building & Construction 4 06-05-2009 06:13 AM
Question on Monolithic slab - Pour all at once? seth Building & Construction 15 05-06-2009 04:36 PM
