Best Way To Build Up On Top Of Cement Backer? - Flooring - DIY Chatroom Home Improvement Forum
Old 11-05-2015, 10:51 PM   #1
Rewards Points: 1,528
Best way to build up on top of cement backer?
Hi.. I have a room I need to tile that already has cement backer board down but there is a 3/4 gap between the top of the cement board and the finished height of the hardwood floor in the adjacent room. I don't know what tile I will be going with yet... Wondering how I can build up under the tile regardless of which I choose to have the tile height match the hardwood?
The floor is 2x10 16" on center 12ft span. Don't know grade or species. With 3/4 t&g ply sub floor and hardie backer 500 on top of that..
ryansdiydad is offline   Reply With Quote
Old 11-05-2015, 11:37 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 780
Ryan,
In this case your Hardie at that level was a mistake, but oh well......too late now. Is the Hardie set into thinset mortar?
If the diff is ", you wanna install Ditra XL and then standard quality/thickness tiles. You should end up very close.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 11-06-2015, 07:24 AM   #3
Yeah it's in thinset.. Long story in the height difference but none of that matters now
Dang that ditra is expensive $300.. This might be stupid but could I put 1/4" hardie on top of the existing board to build it up instread? Would be half the cost..
I knew you would be able to help me out..
Old 11-06-2015, 02:41 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 780
People have done double CBU sometimes. Thinset then nail away.
$300? How much you need? It's worth 3x more than Hardie, am I close?
Jaz
Old 11-06-2015, 04:47 PM   #5
Pretty much right on... I need about 150 sqft..
I will pick out the tile then figure out what I have the stomach for...
Thanks for setting me straight on my options..
Old 11-10-2015, 04:02 PM   #6
Rewards Points: 4
how much cement ,sand and stone including the concrete floor do i need for a three by six extension to my house
skylershay is offline   Reply With Quote
Old 11-10-2015, 04:08 PM   #7
Rewards Points: 4
I plan extend my house with two extra rooms the structure's size is three by six.How cement,sand and stone do i need for such a structure including concrete floor.
How To Build A Laminate Countertop BigJim How To Guides 44 07-08-2015 01:28 AM
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 03:46 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 01:53 PM
