Best Option For Subfloor When Adding Tile Over Hardwood - Flooring - DIY Chatroom Home Improvement Forum
Old 02-19-2014, 11:36 AM   #1
Rewards Points: 61
Best option for subfloor when adding tile over hardwood
My wife and I are remodeling a bathroom in our 1915 Bungalow. Last night, I removed the old tile set in a 1" mortar bed with tar paper backing.
The remaining floor is 2" wide red oak (just like the rest of the house) over 1" by 6" planks. The oak floor is in good shape with the only damage by the toilet. Which is the best option for subfloor for installing 1" hexagonal tiles?
Option A: Should we install cement board directly over the hardwood?
Option B: Should we install a plywood layer before the cement board (but keep the hardwood)?
Option C: Should we removed the hardwood, add plywood then cement board?
Option D: Should we install plywood with a membrane?
Option E: Should we do something different?
KansasCity is offline   Reply With Quote
Old 02-19-2014, 01:03 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
Hi KC,
You should do option "C".
The hardwood gets taken out. Be sure to closely inspect the subfloor and repair or replace any of the planks as necessary. I would then install 5/8" or 3/4" underlayment grade ply, no cheapo CDX. The underlayment will be fastened only to the subfloor, and use no glue. For height purposes you may want to install two layers of underlayment. How's the joists system?
Let us know what materials you're planning to use.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
joecaption (02-19-2014)
Old 02-20-2014, 10:24 PM   #3
Rewards Points: 61
I do not mind removing the hardwood as it'll most likely be reused somewhere else in the house.
The joists are 2" * 8" spaced 16" OC with the planking running perpendicular.
Everyone seems to recommend 3/4" exterior grade plywood, so we will go with it. I plan on using 1/4" hardie board on top of the plywood and 1" ceramic hexagonal tiles.
Old 02-21-2014, 10:09 AM   #4
Tileguy
JazMan's Avatar
Rewards Points: 750
Since the house was built in 1915 I'll assume the joists are a true 2x8". Is that right? Are they in good shape, no cracks, no one drilled large holes or cut outs for plumbing etc.?
You didn't mention the longest span of the joists.
What thin set mortar for the Hardie and the tiles?
Jaz
Old 02-22-2014, 08:39 AM   #5
Rewards Points: 61
Surprising, the joists are not nominal dimensions. All are in good shape but one where someone's plumbing cut went wild. I do plan on sistering a new joist next to it.
The span of all the joists in the room is 10'.
I planned on using fortified thinset mortar for both the tiles and hardie, but am open to recommendations.
Engineered hardwood over vinyl tile - am I being unreasonable or am I getting screwed photopeter Flooring 25 02-01-2014 11:41 AM
Hardwood 1/8 lower than tile schluter edging Pelican Flooring 4 05-05-2011 05:57 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Tile over Oak Hardwood floors (unfinished) [email protected] Flooring 3 07-13-2009 09:07 AM
glued tile to hardwood missmom65 Flooring 7 06-04-2008 11:19 PM
