Best Glue/adhesive For Vinyl Tiles To Concrete Basement Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-06-2017, 01:08 PM   #1
Rewards Points: 420
Best glue/adhesive for vinyl tiles to concrete basement floor?
I have some old floor tiles that feel like vinyl (the same material tiles you would
put on a kitchen floor) that are old are the adhesive backing on them are gone.
What kind of glue/adhesive options do I have? Liquid Nails? 3M 77 spray adhesive (this probably won't work)?
Will liquid nails do the job?
HTFreak is offline   Reply With Quote
Old 06-06-2017, 06:48 PM   #2
Rewards Points: 17,912
Re: Best glue/adhesive for vinyl tiles to concrete basement floor?
Why not vinyl tile adhesive?
http://www.homedepot.com/p/Roberts-1...57-1/100144842
Also going to need a toothed trowel like this one.
http://www.homedepot.com/p/HDX-3-16-...115X/203713857
Carpet in the basement Packer Backer Flooring 17 11-30-2018 02:10 AM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
basement concrete floor leveling ChrisWz Concrete, Stone & Masonry 7 03-20-2012 12:42 AM
Condensation on concrete floor under basement fiberglass shower/tub insert bsande2 Building & Construction 2 01-22-2012 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
