Best DIY Kitchen Floor Options - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By JazMan
Old 09-14-2016, 09:09 PM   #1
Rewards Points: 22
best DIY kitchen floor options
we have sheet vinyl down now,,,its been down 20 yrs,,,in good shape,,,want a change,,,don't want tile or hardwoods,,,can I use NO glue vinyl OVER this floor ?
I don't want to build up too much due to dishwasher nt having a lot of clearance and thresholds,,,
Kitchen is L shaped galley ranch kitchen,,,it transitions into two rooms,,,both hardwoods
luberhill is offline   Reply With Quote
Old 09-14-2016, 09:47 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
Re: best DIY kitchen floor options
All depends on your present vinyl flooring. Most sheet goods are soft and going over will cause problems. If not soft, you can apply an embossing prep product to eliminate the problem of the old pattern telegraphing to the new. But soft flooring will show dents from heels and chairs etc. Loose laid may eliminate the dent problem, but can pucker or tear if not careful.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 09-15-2016, 12:47 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,668
IVC type vinyl will go over old vinyl as long as the old is not a"cushioned" product.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-15-2016, 01:50 PM   #4
Rewards Points: 4,192
I don't think ripping up old vinyl is that much work so I would do that first and then put down the new vinyl.
stick\shift is offline   Reply With Quote
Old 09-15-2016, 02:17 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 642
Core Tec Plus LVT.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 09-15-2016, 04:44 PM   #6
It can be a bear if it is glued. And what if it contains asbestos? It doesn't hurt anything to cover it if it is not cushioned vinyl.
Of course, what do I know. I only have 42 years experience.
Old 09-15-2016, 06:59 PM   #7
firehawkmph's Avatar
Rewards Points: 2,464
If you have a heat register in the floor, you can pop it out and should be able to see the flooring layers. If the vinyl was put down like they normally did 20 years ago, it's probably over 1/4" luan. If you don't see any glue between the luan and the subfloor, the vinyl and luan can be taken up pretty easily. Get a circular saw and set the blade depth at 3/8" and saw the floor up into approx 3' squares. Drive a pry bar under a section and pop then up. If the flooring is twenty years old, asbestos shouldn't be an issue.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 09-15-2016, 07:33 PM   #8
Rewards Points: 22
It's Mannington vinyl...over luan..that is over 1" thick plywood floor...I do not believe this would be considered cushioned....again if I get gget away with 1/4"or less and safe to go over???
Old 09-15-2016, 07:35 PM   #9
Rewards Points: 22
And it IS glued
Old 09-16-2016, 06:57 AM   #10
Originally Posted by luberhill View Post
And it IS glued
Ouch. That won't come up like I said in the previous post. Especially if they used something like liquid nails. A lot of the jobs back then they would use a 1/4" crown air stapler and staple the heck out of it. But it would come up pretty easy.
Mike Hawkins
Old 09-16-2016, 07:48 AM   #11
Rewards Points: 22
the vinyl is glued,,,the luan I don't think is I think its stapled,,,I grabbed the edge after removing the register ad I think I could pull it up
Old 09-16-2016, 01:02 PM   #12
Just cover it up with any loose lay vinyl and be done with it. Don't make it any harder than necessary. Unless the floor is extremely rough, it won't show through.
Old 09-16-2016, 08:05 PM   #13
Tileguy
JazMan's Avatar
Rewards Points: 750
Mannington sheet goods were all rotogravure and therefore cushioned. Doesn't mean it's got ⅛" foam on the back and feels soft, but it does have a thin layer of foam just under the finish/pattern. The foam is very thin but it varies from line to line. New vinyl made to be loose laid should work, but with increased chance of indentation.
The "older" inlaid type are not cushioned and some were smooth. Easily identified cuz they were only made in 6' widths. Your Mannington is probably 12' wide.
Best thing to do is to removed the ~" luan and start over if in doubt.
Jaz
firehawkmph likes this.
Washing machine making "glugging noise"; kitchen sink backing up; bad smells; UGH KDG Plumbing 5 01-04-2015 06:27 PM
Tiling kitchen - Subfloor has a hump. Bigmo59 Flooring 10 09-10-2014 10:29 PM
Kitchen, Dining Room, Pantry mprice214 Electrical 23 07-14-2014 11:45 AM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
