Best Choices For Below Ground Flooring??? - Flooring - DIY Chatroom Home Improvement Forum
Closed Thread
Old 03-10-2014, 06:18 PM   #1
Rewards Points: 356
Best choices for below ground flooring???
Im remodeling my home and Im almost to the point of flooring the lower level. Im leaning towards going with cork. Has anyone come across any issues or anything I should be weary of?? I know the floor isn't exactly level in spots but its like millimeters different so I figured any other type of flooring wouldn't work. Any ideas or help would be appreciated
timothy300858 is offline
Old 03-10-2014, 07:08 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 750
No expert on cork here, but the floor needs to be flat to within 3/16" in 10 ft. and 1/8" in 6 ft. along with the normal requirements.
You'll need to read the directions for the specific item you're considering. You must do the moisture tests specified to a "T".
The method you site to determine how flat the slab is doesn't sound very convincing either way.
So, which specific tile are you considering? Go check the floor using a long straight edge, preferable one that is at least 6 - 8 ft. long. You can use a string with a helper or a laser device made for this purpose.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
JazMan is offline
Old 03-10-2014, 07:11 PM   #3
Retired Moderator
Rewards Points: 7,174
I prefer ceramic tile below grade---water happens---and will not damage a properly set ceramic tile floor---anything less is a risk--however small---a risk none the less.
oh'mike is offline
Old 03-10-2014, 07:27 PM   #4
Rewards Points: 356
Im not using any tile except in the bathroom... Im going to use cork flooring... But thanks anyways
Old 03-10-2014, 07:35 PM   #5
Retired Moderator
Cork is a nice looking floor----follow Jaz suggestions about moisture levels in the slab--if the floor passes the tests--then you should be safe---
oh'mike is offline
Old 03-10-2014, 09:03 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 750
I simply did a little checking and didn't find a recommendation for cork below grade. If you found one that can go below grade if all the stars align, let us know.
Jaz
JazMan is offline
Old 03-10-2014, 09:07 PM   #7
Rewards Points: 356
I was told by someone at a flooring store that cork would be the way to go because of the possibility of the floor not being 100% level....
Old 03-10-2014, 09:23 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 750
Well, he's trying to sell you something. I am not.
But it's not that simple. The floor needs to be flat otherwise it'll look bad. Plus the joints will get off line if the floor isn't within specs, not to mention excess wear at the high spots. Lots of basements are not very flat, many of the walkouts in the last 10 years or so are better than they used to be cuz of the popularity of using ceramics down there. But a cork manufacturer says among other things; Level/Flat - Within 3/16” in 10’ and/or 1/8” in 6’.
I don't know how yours is, you gotta tell us.
You haven't told us which specific tile you want to use. First thing is to be sure it's even recommended for below grade, then you test.
Jaz
JazMan is offline
Old 03-10-2014, 09:26 PM   #9
Rewards Points: 356
Ive already said if its unlevel, its millimeters unlevel.. And Ive said more than once I wanna use a cork flooring...
Old 03-10-2014, 09:41 PM   #10
msaeger's Avatar
Rewards Points: 260
You should change the thread title.
msaeger is offline
Old 03-10-2014, 09:55 PM   #11
Rewards Points: 356
Why is that???
Old 03-10-2014, 09:58 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 750
Yes you said it's millimeters out of flat. (level doesn't matter). So how many is that? 3 -5 - 87 millimeters? In what span?
You wanna use a cork flooring. OK so why ask for recommendations, go do it. If I were you I wouldn't even bother with following any of the directions either. Cork is very nice, it's softer, flexible, quite and it floats.
Possible new title. Need someone to agree that cork for my basement is a good idea, regardless of conditions or manufacturer's directions. Nahhhhh too long.
Hope it works for you.
Jaz
JazMan is offline
Old 03-10-2014, 10:02 PM   #13
Rewards Points: 356
Yeah its 84 millimeters lol... dont reply anymore please
Old 03-10-2014, 10:10 PM   #14
Tileguy
JazMan's Avatar
Rewards Points: 750
You're too funny! APA DACA FRAKA!
Jaz
JazMan is offline
Closed Thread
running ground for new upgraded 200 Amp service mbaldwin Electrical 11 05-26-2013 09:51 AM
Best ground of 3 choices to add ground to circuit? Double Electrical 2 02-13-2013 10:46 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
flooring choices for loft in garage into Flooring 0 02-28-2010 01:19 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
