BEST Adhesive To Glue Down Bull Nose??? HELP ASAP! - Flooring - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 03:44 PM   #1
Rewards Points: 89
BEST adhesive to glue down bull nose??? HELP ASAP!
Hi,
The guy is starting to install the bull nose on my stair steps and I need a really strong grade adhesive. Can someone please recommend a BEST one?
Thank you in advance!
bcdinh is offline   Reply With Quote
Old 07-16-2013, 07:48 PM   #2
Rewards Points: 18,372
Need more info.
Is it wood, some funky limonite poop?
If it's wood to wood then Tite Bond II is what I would use with predrilled holes for galvanized finish nails. The reason I use galvanized is they have a rough finish and hold better.
Old 07-16-2013, 09:34 PM   #3
CitadelBlue's Avatar
Rewards Points: 97
Originally Posted by joecaption View Post
Need more info.
what he said ....
CitadelBlue is offline   Reply With Quote
Old 07-16-2013, 11:16 PM   #4
Retired Moderator
Rewards Points: 7,174
What are you installing,exactly---
Just a curious question,but who is coming and why isn't he bringing the right adhesive himself?
MTN REMODEL LLC (07-16-2013)
Old 07-17-2013, 12:07 PM   #5
Rewards Points: 89
I'm installing solid oak hardwood floor on oriented strand board sub-floor. I'm thinking of using Chemrex cx941 adhesive.
Old 07-17-2013, 02:13 PM   #6
Well that's confusing, your asking about bull nose on a stair tread in one place and hardwood flooring in another.
Hardwood is nailed or stapled not glued down unless it's really wide flooring.
Old 07-17-2013, 04:24 PM   #7
why not nail or staple it?
Old 07-17-2013, 05:12 PM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 710
BCD: You may want to double check two things that I'm not sure/skeptical/cautionary about:
Glue down on OSB... I've never done it, but OSB is kinda flaky, subject to moisture, and I don't know its viability for long term glue-down."
When using natural (non engineered) hardwood, even if a prefinished product which runs a little straighter than natural, how are you going to straighten it and hold it tight/straight without nailing it.?
I have put hardwood on OSB, staple down, but it was 1 1/4 superfloor, and I stapled the heck out of it.... near as I know it is still fine... but I'd much rather be on plywood.
I'm not a harwood installer, just a GC, but you may want to confirm my considerations as above.
Best
Peter
MTN REMODEL LLC is offline   Reply With Quote
Old 07-17-2013, 06:55 PM   #9
Rewards Points: 89
I'm sorry about the hardwood part...the bull nose has no other grip other then to glue it...i'm not using a solid piece of stair step.
Old 07-17-2013, 07:41 PM   #10
Why not a one piece tread? It would be a whole lot easier and less work.
Going to also need finish nails as well as the glue. It just not going to stay in place while the glue dries.
Old 07-17-2013, 11:01 PM   #11
Retired Moderator
Any premium builders adhesive will work--I like PL Premium Never had that one fail me---
Dave Sal (07-20-2013)
Old 07-17-2013, 11:36 PM   #12
Rewards Points: 710
As MIKE says, I love the PolyU adhesives... but rather then a caulk type PolyU glue... I might be inclined to use a liquid type (like Gorrilla)... but you're going to have to prefinish (not the glue part) the parts, to be able to preserve a stain finish and clean the squeeze out off.
Best
Old 07-18-2013, 08:39 AM   #13
firehawkmph's Avatar
Rewards Points: 2,546
+1 on one piece treads. But if you are gluing wood to wood, Titebond II or III would be my choice too. Properly done, it should never come apart plus you would maintain a nice tight joint. I wouldn't use a PL type glue in this situation.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
oh'mike (07-18-2013)
starting point for hardwood floors for 3 rooms mechth Flooring 9 08-26-2010 09:27 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
glue to a mirror Leprichon Interior Decorating 9 04-19-2009 03:16 AM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 08:54 AM
Wood Glue Issue gp1200r Carpentry 4 02-20-2008 12:56 PM
