Bathroom Subfloor & Porcelain Tile Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 11-29-2014, 10:01 PM   #1
Rewards Points: 126
Hi all!
I am in the process of ripping out a (pretty nasty) half-bath and ran across some issues with the subfloor. I plan to tile the floor using porcelain tile.
The bathroom is about 5' x 4' (including the 1/2" drywall) and has a hodge podge of subflooring. It looks like the previous owners have added at least one layer of plywood over the original subfloor with a newer section around the toilet flange.
The floor had linoleum on a luan sheet stapled to plywood. There's also some kind of felt paper stuff in one section and roofing paper under plywood on another section.
In the image above you can see the newer section of plywood, but it is damp and moldy looking in the back corner.
I pulled up the top layer of subfloor in one section and it looked like this:
The whitish looking part is the original subfloor (I think), the black part on the right is the roofing paper.
I would like to remove all of the subfloor and replace to give the new tile floor a better surface.
My plan is to use 23/32" T&G plywood screwed and glued to the floor joists. Lay down modified thin set with Ditra on top of the plywood followed by unmodified thin set for the 12" x 12" porcelain tiles. I think since it's only a 20 sq ft room that I could lay the new plywood down in one piece, but it would be much easier to lay down in two pieces.
My questions are:
First, does this sound like a proper plan? Is the one layer of T&G enough? Should I lay it down in one piece or is two ok?
What's the best way to cut the existing subfloor(s) next to the walls and how close should I try to get to the wall with my cut and plywood replacement?
I have read that there should be a 1/16" - 1/8" gap between the plywood joints for expansion, but shouldn't the T&G joint be tight?
I want the room to be as air sealed as possible, can I caulk or spray foam the joints, around the toilet flange, and around the bottom of the wall 2 x 4's, would that do any good/harm?
I am planning on using 2-1/2" T-25 screws. The box says Deck Screws, is that ok?
I know it's a bunch of questions and thanks for your time!
TeeRiddle is offline   Reply With Quote
Old 11-29-2014, 10:30 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Your plan sounds good
I would cut between the joists with circular saw then pry the plywood off that way.
Give us a pic and size of the joists once you get that far.
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
TeeRiddle (11-29-2014)
Old 11-29-2014, 10:39 PM   #3
Rewards Points: 126
Thanks JetSwet!
The joists are 2 x 8. Not sure of the spacing but I think they are 24". I'll know more once I start pulling the plywood up.
Old 11-29-2014, 10:48 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by TeeRiddle View Post
Thanks JetSwet!
NP!
You don't want to butt the ends of your new plywood too the stud walls because any expansion will cause even slight buckle T&G or not... This will crack the thinset and cause may issues even though it's really only caused by moisture or high heat don't want to chance it.
Old 11-30-2014, 04:36 PM   #5
Rewards Points: 126
I pulled up a chunk of the original subfloor (which looks to be 5/8") and the floor joists are spaced 16" centers.
So now my question is how close should I cut the existing plywood to the walls? I'm thinking I need to get as close as possible. If I leave say 1-1/2" or 2" there will be a height difference between the new 3/4" plywood and the existing 5/8". Or does that really matter?
Old 11-30-2014, 08:25 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
You need to take then entire old plywood out right to the wall studs
Basement Bathroom, drop tile ceiling... Spyrule Remodeling 2 08-01-2014 11:21 PM
A few questions about bathroom remodel clayton993 Remodeling 10 02-10-2011 02:38 PM
Questions on tile work Haff Remodeling 11 12-17-2009 08:01 PM
Options for Old Bathroom Tile Floors mark2741 Flooring 4 11-14-2009 12:21 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
