Bathroom Floor Prep - Flooring - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 08:37 PM   #1
bathroom floor prep
Hello, I am redoing the flooring in my bathroom. After removing the existing carpeting I found the original (9x9) tiles which I am assuming contain asbestos. I have been advised that I should apply a self leveling product over the top of the tiles and lay the new tile over the top. Before I do that I need to repair an area of underlayment in the area of the stool. Existing underlayment is 1/2 inch particle board coated with some sort of polyurethane. However, there is moisture damage to the area around the stool and the particle board failed. My plan is to replace the damaged section around stool with a plywood underlayment and install a vinyl tile. Is this an advisable method to repair the underlayment as well as covering the existing tile flooring?
weekend diy is offline   Reply With Quote
Old 01-30-2014, 09:02 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 780
Answer removed because an ad I did not authorize was inserted within my post.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 01-30-2014, 10:12 PM   #3
I guess I originally thought that but after investigating further found that the existing underlayment was in excellent shape. Also, I am a little concerned with disrupting the existing tile. The tile was probably installed around 1960 and can only assume that it contains some asbestos. The project is a little over 30 sq feet. Should I be concerned about disrupting the old flooring?
Thanks, Bill
Old 01-30-2014, 10:45 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 780
Jaz
Old 02-01-2014, 11:07 AM   #5
Since it is a bathroom, is there any other barrier that should be put down either above or below the underlayment to deal with any potential moisture issues? Do the seams in the underlayment need to be sealed?
Old 02-01-2014, 11:21 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 780
Jaz
Old 02-01-2014, 12:33 PM   #7
We will be using Downs LVT Dynaclic vinyl tiles (11 7/8 x 23 7/8). It is a floating tile.
Old 02-01-2014, 01:10 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 780
Jaz
Old 02-01-2014, 01:39 PM   #9
house was built in 1951 and subfloor is in planks. Still working on demolition but only a small portion on one plank immediately next to stool pipe shows water damage to the point it is a little soft. I believe the subfloor is 3/4 inch tongue and groove by 5 inch wide. I would like to replace with 1/2 inch underlayment to bring back to original height. Manufacture claims are that this is a very tight and water resistant flooring system. This bathroom is utilized mainly as a spare bathroom. Tub but no shower. Will not see the normal traffic and use as the main bathroom.
Old 02-01-2014, 02:14 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 780
Jaz
Old 02-01-2014, 02:54 PM   #11
Thanks for the advise. I will check subfloor and if any doubt will go to thicker underlayment.
Old 02-01-2014, 08:05 PM   #12
Tileguy
JazMan's Avatar
Rewards Points: 780
Ok weekend diy,
Come back any time.
Jaz
Old 02-01-2014, 11:44 PM   #13
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 400
Jaz
Yep, those ads are irritating. I won't endorse products either. They get us because we can't see the ads unless we read posts without logging in.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-01-2014, 11:53 PM   #14
Tileguy
JazMan's Avatar
Rewards Points: 780
I was told recently they're working on it. They were working on it years ago.
Jaz
NEC - what is the purpose of some of these codes ? chez bouton Electrical 32 12-17-2013 03:04 PM
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 08:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 05:22 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
