Basement Subfloor Height / Matching - Flooring - DIY Chatroom Home Improvement Forum
Old 10-15-2014, 08:08 PM   #1
Rewards Points: 22
Basement subfloor height / matching
Working on finishing our walkout basement and thinking ahead to the flooring. We're hoping to do engineered wood throughout most of it, then tile in the bathroom. I've been trying to figure out, 1) The best subfloor for each, and 2) How to get the height of each to match.
After some research, I took my best stab in the sketchup render here:
https://www.dropbox.com/s/uvnik80z3s...oring.png?dl=0
In case you can't see the image, it goes like this:
Living area: slab --> 6mm vapor barrier --> 1.5" rigid foam --> 3/4" plywood --> 1/8 underlayment pad --> 3/8" engineered wood
Bathroom: slab --> 6mm vapor barrier --> 1.5" rigid foam --> 1/2" plywood --> 1/8" mortar --> 1/8" ditra --> 1/8" thinset --> 3/8" ceramic tile
That puts both at the same height - 2 3/4"
My questions:
- Is it ok to put plywood directly on the foam (assuming you tapcon through both into the slab)? Or do you need sleepers in between?
- Would 1" foam be sufficient? We have 8 1/2 foot ceilings, but the less we're eating up with subfloor the better.
Make sense otherwise?? As a side note, I was considering Dricore for the living area, but since it's only 7/8" high, the wood floor would have to be built up to meet the tile floor.
Thanks for the help!
rsax is offline   Reply With Quote
Insulation in basement ceiling for soundproofing -- will basement be too cold? jmai14 HVAC 3 11-16-2013 11:04 AM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
