Basement Stairs Paint Color Advice - Flooring - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 09-15-2019, 04:22 PM   #1
Rewards Points: 98
Basement stairs paint color advice
Hey guys I need your advice. Somebody told me that there's an option to get the same pattern paint as the flooring (Lumbar liquidators 5mm fieldstone vinyl) or another option is paint it the same color as the walls ( Sherwin Williams superpaint Northstar on the walls)
What's in trend these days? I am thinking of painting grey and white like the attached pic. I am open to other ideas too. Is there anything else I should put on the stairs to protect it from damage.
How much does it cost to replace a step because one stair needs some work and I might have to replace it
Thank you!
Basement stairs paint color advice-img_20190915_160210__01_1568578330774.jpg   Basement stairs paint color advice-img-90dd983c6a38c301a352e8968ba3d0ca-v_1568578362321.jpg   Basement stairs paint color advice-img-877ea1025ab6eb3aa43c07bc47608c3c-v_1568578373002.jpg
parmindergill99 is offline   Reply With Quote
Old 09-16-2019, 07:25 AM   #2
retired painter
Rewards Points: 1,780
Re: Basement stairs paint color advice
Personally I'd clean them up and stain them [or not] and apply 3 coats of poly. Poly won't show wear as soon as paint does. As far as paint colors - most any color that floats your boat is fine.
Nealtw, parmindergill99 and tdisss like this.
mark sr is offline   Reply With Quote
Old 09-16-2019, 08:10 AM   #3
Rewards Points: 4
I fixed up a house to sell and stairs in picture were fully carpeted including stringers. I cladded inside and outside of stringer with 1/4” G1S plywood. Capped top of stringers with MDF custom cut. Painted those same as wall and risers have same laminate as floor. Picked up a roll end of carpet for 20 bucks.
Retired guy from Southern Manitoba, Canada.
parmindergill99 likes this.
660catman is online now   Reply With Quote
The Following User Says Thank You to 660catman For This Useful Post:
parmindergill99 (09-16-2019)
Old 09-16-2019, 08:49 AM   #4
JUSTA MEMBER
Rewards Points: 1,536
For safety, I suggest that you paint the treads a Bright YELLOW, that makes them easily seen, in almost any light.
But practicality says that no one will like that, so the alternating grey / white pattern is fairly safe.
Never use carpeting on stairs, it wears easily, then creates a trip hazard, and someone gets injured.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Old 09-16-2019, 08:58 AM   #5
Rewards Points: 2,164
Any color scheme that differentiates the treads from the risers will be safe enough. POs of our current house had gold-colored metal strips put on the edge of each tread into the basement, so not only is there a visual differentiator, there's a tactile one too—and sometimes auditory, when you step on a strip and it goes clank.
de-nagorg and parmindergill99 like this.
huesmann is offline   Reply With Quote
Old 09-16-2019, 12:42 PM   #6
Rewards Points: 98
So first you stain it with whatever color(satin or semi gloss? railing is semi gloss) and then apply oil based polyurethane on top?
Old 09-16-2019, 12:45 PM   #7
Rewards Points: 98
haha I was thinking of doing something like that to protect the edges
Old 09-16-2019, 01:05 PM   #8
Rewards Points: 4
Basement stairs in my house have carpet tile glued and aluminium nosing nailed onto treads.
Basement stairs paint color advice-img_2447.jpgBasement stairs paint color advice-img_2446.jpg
huesmann and parmindergill99 like this.
Old 09-16-2019, 02:14 PM   #9
retired painter
The stain won't have a sheen to speak of and needs poly applied over it to protect the stain from wearing away or attracting dirt/grime. The 3 most common sheens of poly are satin, semi-gloss and gloss.
Old 09-16-2019, 04:33 PM   #10
Rewards Points: 98
I used SW super paint satin on walls so when I asked the guy about stairs yesterday he said I can use the same paint on the stairs. Oil based or water based poly? (if oil, won't that make it slippery?) Thank you
Old 09-16-2019, 04:36 PM   #11
Rewards Points: 98
Attachment 571285Attachment 571283
Do I need nosing?
Old 09-16-2019, 05:01 PM   #12
JUSTA MEMBER
You can always get them to add a little sand to the mix, to add traction.
As for edge protection (nosings), only if you worry about the edge wearing off first, which it will, because people slide their feet, on and off of treads.
ED
Old 09-16-2019, 05:04 PM   #13
Rewards Points: 4
Do I need nosing?
No but It just finishes the edge better and the edge doesn’t blend in.
Old 09-17-2019, 06:40 AM   #14
retired painter
The problem with adding sand to paint is it tends to wear off on the high traffic areas - where you need it the most. I like SuperPaint but no way would I use it on a floor/steps.
The Following User Says Thank You to mark sr For This Useful Post:
de-nagorg (09-17-2019)
Old 09-17-2019, 06:53 PM   #15
Rewards Points: 98
Should I get this tread replaced?
Basement stairs paint color advice-img_20190917_183826_1568760671903.jpg   Basement stairs paint color advice-img_20190917_183811_1568760688762.jpg
