Basement Floor Prep. - Flooring - DIY Chatroom Home Improvement Forum
Old 03-16-2016, 04:01 PM   #1
Solutions (handyman)
Rewards Points: 488
Basement floor prep.
The question is; when framing a concrete basement, does the flooring (covering of concrete ... insulated or otherwise) go no first and the framing attach to the new floor surface? Or, does the framing go first (from upper floor joists to the concrete) and the flooring go in after? I have seen both but not sure the reasoning behind both. Thanks.
Mark Harvey is offline   Reply With Quote
Old 03-28-2016, 02:13 PM   #2
Rewards Points: 610
Re: Basement floor prep.
Framing first to allow for installation variances and some hammering to put wall framing in place. Then drywall, flooring and baseboards. IMHO..I am not a carpenter.
techpappy is offline   Reply With Quote
The Following User Says Thank You to techpappy For This Useful Post:
AlexEverette (03-28-2016)
My Basement Journey tojo78 General DIY Discussions 8 06-23-2017 08:53 PM
Insulation in basement ceiling for soundproofing -- will basement be too cold? jmai14 HVAC 3 11-16-2013 11:04 AM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
