Basement Bathroom Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-24-2014, 10:07 AM
Rewards Points: 52
basement bathroom subfloor
Hi there,
I am in the middle of a basement reno which is going fairly well. Learned a lot, made some mistakes (which were fixed) but things are going nicely.
The one area that I still haven't made up my mind on is the bathroom subfloor.
There is some waves in the floor that I am worried about....I was thinking of putting down a SLC, which I would then place ditra and tile on top of that. I will be installing a pre-fab shower which I havent bought yet and I am thinking that having a perfectly level subfloor will help with that. I don't want the pan cracking after a year or two because of an uneven subfloor.
Alternatively, I could use dri-core or delta-fl with 5/8 T&G plywood or OSB. I'm trying to ensure the threshold with be approximately the same height as the carpeted area (which will be delta fl with T&G OSB).
Any thoughts or advice?
Onagoth is offline
Old 11-24-2014, 11:59 AM
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 398
One thought. Do not put OSB on a concrete floor. It WILL fail.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is offline
Old 11-24-2014, 03:18 PM
Tileguy
JazMan's Avatar
Rewards Points: 780
Oh no you won't. You can not put tiles over that stuff.
Your original plan of SLC plus Ditra is a great way to go. Do the SLC to level the floor before the shower base.
The ceramic floor will be lower than the Delta FL/carpet and it's the way it should be.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
JazMan is offline
Old 11-24-2014, 05:22 PM
Rewards Points: 52
Thanks guys
How much lower should the tile be compared to the carpet....in other parts of our house the carpet underlayment is virtually the same height as the tile.
Onagoth is offline
Old 11-25-2014, 04:44 PM
Rewards Points: 5,012
If it's concrete maybe this will help, you can rent one.
ron45 is offline
Old 05-25-2015, 09:10 AM
Rewards Points: 52
Jaz
Hi Jaz,
Can you elaborate a little on this? I should be doing this (finally) this week. My intention was to use SLC and ditra to raise the bathroom floor height to the height of the finished floor of the adjacent room (1.5").
Is that not advisable? I'm a little torn since ensuring a flat transition room to room means spending about $300 on SLC and primer.
Thanks,
Onagoth is offline
Old 05-26-2015, 04:08 PM
Tileguy
JazMan's Avatar
Rewards Points: 780
I wouldn't raise the floor the entire amount. When you start level, the carpet will be higher because of the padding and the length of the carpet pile. The carpeting will compress so you should feel the edge of the tiles and the higher carpeting makes it look more luxurious.
You should be able to keep the tiled area a bit lower, maybe ", but that depends on the type of carpeting.
Remember SLC will try to find its own level and doesn't care where you want it to flow to. It needs a little help to flow too, but don't mess with it too much.
Jaz
JazMan is offline
Old 05-26-2015, 07:42 PM
Rewards Points: 52
The finished floor isn't carpet, so i don't expect compression. In that case, I take it that its okay to be flush with the finished floor?
Onagoth is offline
Old 05-26-2015, 09:32 PM
Tileguy
JazMan's Avatar
Rewards Points: 780
OH, it's not carpet? Where did I get that idea?
Not knowing (now) what types of flooring will meet in the jamb, I guess flush will be good. I was also thinking you might want a marble threshold, but maybe not?
Jaz
JazMan is offline
Old 05-26-2015, 09:51 PM
Rewards Points: 52
Oops....forgot the detail in the first post....we decided against carpet. ..haven't figured out the transition yet. ...
Onagoth is offline
The Following User Says Thank You to Onagoth For This Useful Post:
JazMan (05-26-2015)
Old 05-29-2015, 10:24 AM
Rewards Points: 402
To do the right job with SLC, try to follow complete directions mentions behind the pack, Primer is a big yes when making SLC or else there is high risk of SLC not bonding properly.
fortunerestore is offline
Subfloor or no in basement? mklein49 Remodeling 9 01-02-2013 10:03 PM
Framing basement walls on top of a subfloor eng34ladder21 Flooring 0 12-23-2012 01:37 PM
New Basement Bathroom / Laundry Room Electrical Circuit(s) Rookie11 Electrical 5 12-11-2012 09:52 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 10:06 AM
