Baseboard Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 10-02-2014, 10:42 PM   #1
Rewards Points: 115
Hello,
Attached are two pictures of a baseboard transition b/w carpet and hardwood that was installed by the builder of our house. We had no say as to what was done, since we bought the house as a spec house. First pic is standing in doorway between kitchen and dining room to the right, 2nd pic is from in dining room looking towards kitchen. The hardwood has shoe molding with the baseboard, while the carpet does not have shoe molding. The top of molding is slightly different in height between the carpet and hardwood, so that block breaks it up, so you dont really see the height difference because they are not butted up against each other. Does anyone know if the block that transitions between the two floors is a specialty piece of baseboard, does it have a name? Its not just a solid piece of wood, the top edges of the block all have small chamfers on them. Was not sure if you can buy this somewhere, or if it was just extra carpentry work.
I am asking this, because I want to do something similar in our basement that I am finishing. The upstairs flooring does not have a transition strip between tho 2 flooring types, the carpet is just shimmed to match the hardwood. In our basement I have carpet going to 1/8" vinyl and have a transition strip connecting the two. (http://www.covebase-n-transitions.co...ion-Strip.html) The link is to the transition strip we are using for the carpet to vinyl. It has 5/16" gap for carpet to be tucked into, and then a 1/8" notch for the vinyl to slide under. What I want to do is where the transition strip comes up to the wall, I want to place a similar block as seen in the photos up against the wall, and have the transition strip run right up to it. That way I can have molding at diiffernt heights to the left and right of that block (carpet approx 3/8" off subfloor) and vinyl (1/8" off subfloor), but then the block breaks up that height difference, and I do not need to rip down the molding in the carpet areas to match.
Few questions
1. Does anyone know what that block is called, is it a specialty molding, can I buy it somewhere, or just need to do some extra wood work?
2. Does the basement install of moldings with that block sound good?
Let me know if you need clarification on anything, I tried to include all pertinent info.
Thanks,
Steve
svaic00 is offline   Reply With Quote
Old 10-02-2014, 10:47 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That one looks kind of simple and home made compared to the baseboard profile. You can buy those things at home centers. They may be called "baseboard terminals" or something like that. I have heard people also call them "plinth blocks" but that really isn't a plinth block in my thinking. You could have some made easy enough or maybe even make them yourself.
XXX
Old 10-02-2014, 10:49 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now that I look at that thing I'm thinking it isn't any kind of a standard item in trim-work, it looks out of place there to me.
XXX
Old 10-02-2014, 10:53 PM   #4
Rewards Points: 115
It happens at 4 or 6 locations on the first floor, mainly in the open foyer/open family room layout where carpet and hardwood meet. Where the hardwood meets carpet at doors like in our office den, there door casing and trim seperate the molding on hardwood from molding on carpet.
Old 10-02-2014, 10:59 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Oh yow you see them here and there but I think they are conjured-up on-site. Different floor coverings require different baseboard elevations sometime and that's a way to help disguise the change-up. I've done it myself but I always had to make my own. I have seen similar objects in home centers but don't know for sure what they would be called.
XXX
Old 10-02-2014, 11:53 PM   #6
Few questions
Steve
That is called a plinth block.
QueBall is offline   Reply With Quote
Old 10-03-2014, 12:35 AM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 518
Why not just rip a 1/4 inch off the base and run it on around the corner so the tops will match. What is there now does not look good IMHO. It looks like something made up on the spot.
A suggestion if you are wanting to go that way, why not go with a wooden corner guard like the one below. If it isn't thick enough then you could make a plinth block under the guard to kill the base into.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 10-03-2014, 07:59 AM   #8
Rewards Points: 18,244
That's one ugly way to make that corner.
Install the base by setting short scraps of base under it where that hardwood is and keep all of it at the same height at the top when making that corner.
The 1/4 rd. covers up the gap, in your case I'd consider using shoe instead of 1/4. That big 1/4 round looks kind of clunky to me.
Old 10-03-2014, 09:08 AM   #9
Rewards Points: 115
This is how my kitchen/dinning/family room are where hardwood meets carpet. I am not looking to change this area. What I want to do is use the same concept idea in basement, at the location where I will have a transition/reducer to go from carpet to vinyl. Since carpet is thicker than the 1/8" vinyl, I took my options as ripping the molding down 1/4" so they would be same height, or do something as shown in attached picture. Do not really want to rip it down, don't have a table saw, and have not had the best cuts in ripping with circular saw. I know I could make a jig and all that to help. The picture shown is on a flat wall, where these two floors meet.
In the picture is what my thoughts were for doing the basement, to the left is carpet with molding, to the right is vinyl with molding and shoe (plan to use shoe, not 1/4 round). The transition/reducer connects the two floors, and my whole question is how to transition the molding between the two floors, so I was thinking of using the plinth at the location where the transition is to transition between the molding on the two floors, along with them being different heights. Drawing is not quite to scale, you can click on the link to see a better picture of the transition from my original post.
Thanks,
Steve
Old 10-03-2014, 09:10 AM   #10
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 318
It would look better if the carpet installer had done a better job. There should be no dip in the carpet on that corner.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-03-2014, 09:13 AM   #11
Rewards Points: 115
I understand that, I had no say in it. The house was built for someone else, they lost financing, we bought house as a spec house because price was dropped significantly cause builder did not want to carry it, never noticed that dip until you pointed it out, but this is an area upstairs that I am not changing, my work is in the basement.
baseboard transition - Can't get that angle JohnDeknis Carpentry 15 08-15-2016 03:31 PM
How to join two 1x6s to form a 23' baseboard with a seamless transition? amakarevic Carpentry 12 09-14-2014 11:34 AM
Baseboard. A Big Deal Question! altc81 Flooring 15 11-03-2013 04:00 PM
Wall tile to baseboard transition? wraiththe Remodeling 11 01-10-2012 08:29 PM
How to transition from door casing to baseboard? RxScram Carpentry 12 11-14-2009 12:10 AM
