Backer Board Repair Or Replace? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-09-2016, 11:03 PM   #1
Rewards Points: 4
Backer board repair or replace?
Hello all first post here. I am trying to do my first DIY tiling project. I have the first piece of backer board down didn't have to cut it. The 2nd piece however I scored it and when I went to snap it it just ripped randomly down the line. Pictures as shown. Would I be able to repair this with fiber tape and thin set? or should I buy a new board and try again? Where its torn after laid down would be about center of the room.
lazyman is offline   Reply With Quote
Old 01-10-2016, 06:59 AM   #2
Rewards Points: 7,555
For $12 should you even consider wasting tile and quality of job?
Some might. I would throw it away, call it experience and do it right.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
oh'mike (01-10-2016)
Old 01-10-2016, 10:12 AM   #3
Rewards Points: 4
thank you for the advice i will replace it. It's been a longer project started off pulling up laminate to practice putting tile down the found out the subfloor was rotting due to an undiscovered leak. had to pull the whole subfloor up and replace. been a large learning experience. thank you for the advice
Old 01-10-2016, 10:30 AM   #4
ZZZZZ's Avatar
Rewards Points: 1,160
Lazy, did you use a knife designed for cement board? (not a standard utility knife)
You'll get cleaner and easier to make cuts with something like this:
http://www.homedepot.com/p/HDX-Cemen...015X/203714421
ZZZZZ is online now   Reply With Quote
Old 01-10-2016, 10:48 AM   #5
Retired Moderator
Rewards Points: 7,174
When snapping Hardibacker---use the scorer pictured above---then place your knee on top of the score and pull UP---just the opposite of cutting drywall---
Be sure to set the rock into thinset before nailing---(like a giant tile)
Old 01-10-2016, 02:08 PM   #6
I hear you. I am going through the exact same thing right now. I got the first layer of the sub nailed in place and hope to get the 23/32 layer nailed in place on Monday. Then I will be ready for the hardie.
Colbyt
Old 01-12-2016, 08:20 AM   #7
Rewards Points: 4
I bought a backer board score man it made it so much easier. I am about ready to begin laying down the tile only I noticed my floor in one corner is uneven It's pretty bad. Should I use cement leveler or can I float it with thin set? Good luck Colbyt Hope your project goes well. I know I'm learning alot.
Backer board repair or replace?-20160111_180653.jpg   Backer board repair or replace?-20160111_123947.jpg
Old 01-12-2016, 08:21 AM   #8
Rewards Points: 4
For some reason they put the pictures weird sorry about that guys
Old 01-12-2016, 08:48 AM   #9
Can't tell where that slope is from the picture. A quality tile job needs flat more than absolute level. Of course if that slope sends water in the wrong direction it could cause future problems.
That is out a full bubble if I am seeing it right. Where is it low?
Colbyt
best way to fasten backer board? ponch37300 Flooring 19 04-10-2017 09:46 PM
Backer Board Around Tub Deteriorated. devnull88 Plumbing 2 05-18-2011 04:56 PM
Backer Board Around Tub Deteriorated devnull88 Building & Construction 3 05-16-2011 10:18 PM
How Do I Patch Tile Backer Board? rajrae Tiling, ceramics, marble 1 11-17-2008 10:43 PM
Backer Board Thickness poolecw Flooring 3 10-09-2008 02:30 PM
