Attic Flooring: Ok To Flush Cut Joist Hangers That Are Sticking Up? - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Like Tree21Likes
Old 05-21-2019, 06:06 PM   #46
Rewards Points: 151
Re: Attic flooring: Ok to flush cut joist hangers that are sticking up?
I'm just going to have someone look at it.
Thanks everyone.
Nealtw and HenryMac like this.
"Dracarys" - Darth Vader, from The Wrath of Khan
tgm1024 is offline   Reply With Quote
Old 05-22-2019, 08:03 AM   #47
HenryMac's Avatar
Rewards Points: 1,002
Originally Posted by Nealtw View Post
I would put 2 ply 2x10 beams between the joist from the outside wall to the center bearing wall then build the 2x6 deck sitting on those. moving it all or most of it over to the 12' side would be better.
Wow... just wow. Think about the logistics of this Neal.
28 foot 2x10's, into the attic of a 2 story home?
HenryMac is offline   Reply With Quote
Old 05-22-2019, 01:02 PM   #48
retired framer
Rewards Points: 22,596
You have never sistered rafter?
Do not use flat bottom gables with scissor trusses.
Old 05-23-2019, 11:00 AM   #49
HenryMac's Avatar
Rafter? We're talking about floor joists / ceiling joists.
So you're suggesting he cut the new 2x8 floor joist's up into short pieces and splice them?
Show me the span table for a 28 foot long 2x8 that's cut into pieces and spliced back together with more cut-up 2x8's.
Old 05-23-2019, 12:29 PM   #50
retired framer
There is a bearing wall 16 ft. and I am talking about 2x10 so the load of the new floor does not touch the ceiling joists.
As far as getting 16 foot 2x10s in the attic, soffit vents or you cut a flat slot near the ridge.
Old 05-23-2019, 12:36 PM   #51
Still learning every day!
F250's Avatar
Rewards Points: 806
When I did my attic work, I was able to slip my 16' 2x10's up through my daughter's bedroom window, and then straight out her bedroom door into the new door entry to the attic space. Had to store them stacked on diagonal, though, until I could cut/install each one individually (actually only needed about 14.5' lengths).
Nealtw likes this.
Pete
Bark less, wag MORE, and Show Compassion to everyone you meet!
F250 is offline   Reply With Quote
Old 05-23-2019, 12:50 PM   #52
retired framer
Once you figure they have to get there, you will find a way.
Old 05-23-2019, 01:21 PM   #53
Rewards Points: 151
Ok, I need to provide some further insulation clarification.
Please ignore the rest of this post if it's of no interest to you. Save yourselves. Run. Insulation now is of no interest to me.
I have a childhood knee injury (cartilage removed) that decided to uncharacteristically flare up in the last couple weeks, so I've been reticent to clime those @#$%ing attic steps.
When I looked up there again, I noticed that what was there was in fact the 2x10 insulation in between the 2x8 joists with some spots tufting up in patches an extra 2-3 inches. So I'm not worried about the insulation now.
Old 05-23-2019, 01:30 PM   #54
Rewards Points: 151
Framing: Allow me to recap:
1. D-Fir used. 2x8 in attic, 16 oc.
2. Two sets of spans, as indicated.
3. Chart that I supplied shows that even #2 16' spans can support 20 llb/sqft.
4. Attic "beam" fully supported through each floor, bearing straight to the beams in the basement. Same exact span as the 2x10's on every floor.
5. (new count): The collar ties (maybe 7-8 ft. overhead) are of count 9. They might be functioning as rafter ties because of how far down they are.
6. I'm interested in 16'x16', centered over bearing support.
Is the guy I have over going to catastrophize and say "no" to upsell me on engineering, and/or is this simply too much worry?
Nealtw likes this.
Old 05-23-2019, 05:00 PM   #55
Property Mgt/Maint
Rewards Points: 6,728
I would surprised if didn't say you are fine and good to go. You are not asking to convert the attic to living space.
tgm1024 and Nealtw like this.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 05-23-2019, 09:39 PM   #56
HenryMac's Avatar
As long as that "bearing support" you speak of in item 6 includes load bearing support walls on the 2nd and 1st floors... the guy should rubber stamp the project.
Old 05-24-2019, 08:33 AM   #57
Rewards Points: 151
Yeah, that's what I've been trying to say (#4). Sorry if my non-contractor phrasing wasn't clear enough.
Thanks again, and in any case :
Dave Sal, Yodaman, Nealtw and 1 others like this.
Old 05-27-2019, 09:19 AM   #58
HenryMac's Avatar
Be sure to let us know what the pro tells ya.
Old 08-20-2019, 10:54 AM   #59
Rewards Points: 151
Probably best to not get into his phrasing.
It's a non-issue.
Tags
2x8 , attic , flooring , joists
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 06:53 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
how to remove joist hangers Tonglebeak Building & Construction 5 09-08-2010 12:16 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
correct joist size for attic helpless handyman Building & Construction 1 07-05-2006 11:29 PM
